    jcb
    Sep 2005
    uk
    4,077
    are ball joints "cast" into the OEM arms?
    have some spare arms and was looking at how the ball joints are joined to the arm.
    was just doing a bit of reverse engineering!
    as far as I can see they much be part of the casting process.
    any ideas?
    May 2010
    Bedford
    2,877
    The TRE`s are listed as a seperate part on ETKA. Although says its a repair kit but still 50quid each plus the vat but if you buy the kit which would have the arm and the end its the same price...
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    jcb
    Sep 2005
    uk
    4,077
    no I mean the ones in the arms.
    no visible insert, though they might be pressed in but cast ali would crack I guess
    May 2010
    Bedford
    2,877
    Oh suspension arms. Sorry. Yeah pretty sure they arent listed as a separate but cant be 110% without being at work to check. But cant say i`ve ever seen them separate. They are on some models but the A4 i`d say no.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    I guess given steels much higher melting point it would be pretty easy to make it part of the casting.
    It could still be pressed in though, the alloy wont crack so long as the interference fit is done to the right tolerances.
    TD5 Land Rover Defender build
  1. Rear Tie Arm Replacement-too adjustable camber arms "How To"
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2011, 14:31
  2. Ball joints.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 09:24
  3. Wishbone ball joints.
    By ayfreetee in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2011, 08:30
  4. Ball joints, cv boots, bushes & bearings
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 19:59
  5. insurance - admiral wont insure "remap" only a "chip"!
    By s3paul in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st April 2010, 20:11
