Volks AutosSky Insurance
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By aragorn
Thread: Big wheels
    Apr 2010
    52
    Big wheels
    Hi all
    Would 19inch wheels with235 35,s go on my s4?I will be fitting either eibach or h&r springs(only). Do i need coil overs to do this?
    cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    should do, exact fitment is offset dependant, but they should go on with the right wheels.
    TD5 Land Rover Defender build
    Nov 2010
    Scarborough
    103
    I've got 19x8 et25 and 235/35 rear and et33 and 225/35 front but on a fwd chassis.This is just on sport springs so not low.Probably got about 25mm arch gap at the rear and 35mm at the front.The wheels sit mor or less flush with the arches.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    Apr 2010
    52
    nice one lads...
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    167
    As Aragorn says....."You will need to check the offset" ......
    I have just tried to fit a set of 17 x 8.5J ET50 wheels with 245x 45 17 tyres on my QTS. I dont know if the S4's arches compensate bigger wheels ?!
    On mine, with the above wheels fitted EVEN with a 15mm space on the back the tyre was still touching the upper rear arm and the tyre was starting to stand out like a sore thumb from the wheel arch!
    "Stick a V8 in it!"
    14,900
    245's are a little wide TBH and at that width the height (45) is too big, and ET50 is too high.
    I suspect if you dropped to a 225/45, or maybe a 235, you'd get them on with some careful spacing.
    Apr 2010
    52
    Im gonna leave it and go 18s.RS4s to be exact.Thanks again chaps..........
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    If you're going GENUINE RS4's, then you'll have to be careful with the tyre choice as the rims poke out a bit, when compared to standard A4/S4 rims...
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    I have 19x9j allround, fitted with 235/35/19. lowered using H&R springs -30mm, and they are absolutley no problem!
    Audi S4 quattro cabriolet in dolphin grey metallic, Audi exclusive crimson red leather/black piping, red hood, carbon inlays, RNSE, tiptronic gearbox with paddleshift, electrically adjustable & heated seats, 6 disc multichanger, DVD multichanger, monitors in headrestraints, xenon headlights with power wash, cruise control, folding door mirrors, storage pack, 19" OE VW Touareg wheels with 25mm spacer/adapters all round, non res cat back quad tipped Milltek exhaust, lowered 30mm on H&R springs
    "Stick a V8 in it!"
    14,900
    Your sig also suggests you have a B6...
    Ben_Lucas43 likes this.
  1. Does anyone have any mint A3 Sline wheels or Black Edition wheels for sale?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2011, 18:44
  2. Alloy wheels: What OEM wheels will fit / seeking OEM items.
    By DavieMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th January 2011, 22:11
  3. Wheels. Nice Wheels.
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2008, 18:47
  4. New wheels or keep the standard wheels and drop it?
    By Bong Water in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2008, 23:27
  5. What OE Audi wheels for winter wheels? Suggestions please.
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2005, 16:54
