EM TuningMonster Motorsport
Thread: xenon lights??
    Jul 2011
    10
    xenon lights??
    Looking into fitting xenon lights to my B5 A4 Quattro as the standard lights are hopeless!! I found a company that i can get the wiring from, link below
    KUFATEC GmbH & Co. KG - A4 - B5/8D
    does anyone have the part numbers for the xenon lights for the B5 A4, as im going to price them up through audi. i know they'll be expensive which means i'll probably try an source them 2nd hand
    Thank
    Scott
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Set on eBay - 280731678608
    Jul 2011
    10
    thanks i'll get in touch with the seller an see what come of it, still wouldn't mind the part no's so i can check audi prices aswell
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    If you already have the projector lenses, then why not just buy a hid kit for £30 off ebay. Does the same job, except doesnt have the auto-level function. But every Audi/Car i've owned with the projector lense, I;ve found i've never needed to adjust the height/angle of beam pattern,
    Only when fitting hid into a normal lense do they need realignment.
    Dan
    2002 2.5 V6 Quattro
