EM TuningChris Nott
    imported_christhick
    Anyone had probs with their indicators
    My indicators seem to be playing up occasionally. The indicators flash once or twice and then stay on permanently. The light on the dash also stays on ‘green’. The hazards work fine so I’m sure its not the relay, fuse or a bulb fault.
    Has anyone had a fault indicator stalk which needed replacing?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Re: Anyone had probs with their indicators
    New one on me. Maybe a case of stripping down, cleaning the contacts & putting it back together.
    imported_VaulterTim
    Sounds like that's your flasher unit mate... basically a relay. It stops after a few flashes because the coil is probably knackered and heats up and breaks down after 1 or two operations.
    Just a thought...
    Nov 2004
    England, UK
    63
    Im gettin a prob when i indicate left - it dont seem to cancel out most of the time and keeps on indicatin left. Some times it does cancel out so not sure what it is.
    imported_christhick
    I'm hoping someone will say its a problem with the indicator stalk. Then I can justify replacing it with cruise control!!!
    Its another clitch for the mechanics to look at when they do the Cambelt.
    Cheers for your help lads.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Good thing you didn't post this question on a BMW forum. [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
