    Apr 2009
    thorpe surrey uk
    22
    Electric window woes
    Here is the problem ,after a day out in the car with no problems pulled up outside house went to close drivers window and it closed and then reopened,closed again and now does not work at all .The other thing is now the passenge window can only be opened from drivers door switch .Thinking of getting rid of the car fed up twith the problems i have had over the pass three years ,new cat new window switches new headlamp switch door dropping and more which i cant be arsed to think about.
    Please help scott fed up with Audis
    Jun 2011
    9
    Mine did something similar when the window came off the runners
    B5 2.4 v6 30v tip ¦ currently stock ¦ long list of jobs todo
