if your aiming for 500hp then they're desirable for sure.
They are the same as the cams out of a 2.4 v6 though, and often suffer from wear to the case hardening due to the **** oil audi specified on the RS4 so bear that in mind if your buying used.
Personally, i'd probably look at simply buying a complete set of 2.4 heads with cams and fitting them complete (with the correct exhaust valves) if i was going for a serious 500hp. That way your getting the larger ports and the cams and lifters all matched together. Given that complete 2.4 engines can be had for a couple hundred quid, it seems the cheapest option to me.
