Chris NottEM Tuning
Results 1 to 15 of 15
    gmx
    Feb 2009
    Sydney
    133
    Steering rack ratio... possible upgrade options??
    Does anyone know the standard rack ratio for the AJLs ?
    There seem to be two part numbers for AJLs. One is common to all N/A & Tdi V6s, the other is AGB (2.7T) & AJL only.
    Are these interchangeable?
    Is the S4 ratio faster?
    Can S4 and in-turn... us AJL guys upgrade to RS4 racks if they're any faster?
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,923
    Doubt it as the track is different between the A4 an RS4 models. You might be able to build an RS4/S4 hybrid rack if you were that way inclined.
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    Track difference is all in the wheels.
    The suspension etc is geometrically identical between an A4 and RS4.
    As for the rack ratio, no idea!
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,923
    Really? They pushed the wheels out that much further just by using a smaller offset?
    I thought they were ET20 as opposed to the A4/S4's ET35-42. That only increases the track by a total of at most of 44mm per axle. I always thought the RS4 was a fair bit wider than that.
    Not saying you're wrong, just that I would be surprised
    www.passionford.com
    "Stick a V8 in it!"
    14,909
    A4/S4 as stock is ET45, so your gaining 50mm of track over a stock S4 but then the wheels are 8.5" rather than 7.5 so you get some extra width from that as well filling out the bigger arches.
    The uprights, control arms etc are all the same.
    gmx
    Feb 2009
    Sydney
    133
    Hrmm, going off topic more and more here. I had a slight suspicion that the upright was different as well, hence the lower front control arm was more B6+ style but still had the fatter shock absorber bolt like all B5s.
    So for ex, to use B6 uprights. Instead of B6 LCAs with a spacer, we could just use RS4 arms.
    Yeah the rack ratios tend to be a bit of mystery. The only numbers I can find are US Spec LHD.
    "Stick a V8 in it!"
    14,909
    The uprights are aluminium, which means they use the smaller taper on the balljoint, and yes, that means the arms are a little different, but geometrically they are the same length.
    There are two different racks. ETKA is a bit unclear, but it seems that the S4, RS4 and PR-1BV models have the same rack, and everything else uses a different one.
    UK TQS's are all PR-1BV, which means quattro gmbh suspension package. Basically they fitted the TQS with S4 suspension and steering.
    I've noticed this oddity before, in the track rod end section. TQS's come with S4 spec solid rod ends, as a result of the aforementioned PR-1BV. But if you look up the AJL code engine, it suggests the proper fitment is the standard A4 rubber joint.
    Also bear in mind the facelift racks are different to pre-facelift ones.
    gmx
    Feb 2009
    Sydney
    133
    1BV as in on the vehicle data sticker?
    Mine says 1BE and in the decoder there doesn't seem to be any difference between them. Both say "Sport suspension/Shock Absorption"
    At least this means they're completely interchangeable.
    "Stick a V8 in it!"
    14,909
    1BV is specifically Quattro GMBH suspension according to ETKA.
    TQS's in the UK differ from normal A4 Quattros because they have cast upper rear wishbones instead of pressed steel, they have solid track rod ends, different steering rack, and built in strut brace on the front end (although all 6 cylinder cars got the strut brace after facelift afaik).
    The TQS here was a special edition, limited run car, and had a bespoke half leather interior and white dials too.
    Does your car have these features?
    gmx
    Feb 2009
    Sydney
    133
    In response to the previous question, I don't have most of those (white dials, strut bar). I haven't checked the rear wishboes. TREs are solid but they could have been replaced prior to me knowing.
    The only things we got were improved interior, quattro (Fwd models remained AEB or APU), manual only afaik, 17x8 ET35 ronal rims. They look exactly like yours but you reported they were 17x7 ET45 or 17x7.5. Mine are definitely 17x8 ET35.
    bringing this back as it's been on my mind.
    Are the fittings different between the UK TQS and other 1.8Ts? So apart from just the rack, would I need fittings and lines to do the swap?
    Does anyone know the exact ratios? If the S4 is the same as RS4 then 99% of the information out there on the net is worthless anyway. Similarly, if the rack is only slightly tighter, it would be hardly worth it.
    Are TQS racks easy to source there?
    Is it possible to modify racks for a tighter ratio?
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    Do the RS4 lower arms not mount in the outboard hole in the subframe? I always thought so as running RS4 bits then requires spacers between the gearbox flanges and the inner CV so I assume its not just the wheels, but could be wrong.
    2000 Audi A4 B5 Quattro Sport - My build thread - Click
    2004 Volvo S60 D5 - Daily smoker & race car tow truck
    1993 Audi S2 ABY - Dead & buried
    1990 Audi Coupe 2.2E - Dead & buried
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    Quote Originally Posted by gmx View Post
    The easy answer is yes, but it won't look very OEM more racecar if you like. Google steering quickener. Not sure I would use one though
    Link-
    Steering Quickeners - Racing Parts and Products
    gmx
    Feb 2009
    Sydney
    133
    I've heard of them, they seem to be popular with drifters here.
    I came across this with further searching. Made to suit the B5 Passat, probably same as the A4.
    Steering rack quickener - QSP 1:1.5 - Tuning-in.eu
    I think I'll get the car setup sorted a bit more then follow this up further.
    "Stick a V8 in it!"
    14,909
    TQS boleros are 17x7 ET45. I have 24 of them lol, and they're all the same.
    ETKA suggests the AJL has its own special pressure hose for the power steering. The return hose however seems the same as all 4 cyl petrols. I've never looked at these up close though. I do however have a 1.8T FWD sitting on the drive to be stripped soon, so i can compare the rack and its fitments with my car at some point if you want?
    In2Deep: RS4 and S4 driveshafts are the same (and they're also used on AJL 1.8T FWD models in europe, we didnt get those here though).
    Some late S4's got the same alloy uprights as the RS4 too, using the same control arms, further clarifying that they are the same.
    gmx
    Feb 2009
    Sydney
    133
    Did ETKA mention it was AJL or some derivative (ie those in UK market or with PR-1BV suspension/option?)
    Yeah, my boleros are definitely 17x8 ET35... I was shocked myself as I thought I was getting more width with my BBS (7.5 -> 8). I recall they used them on A6 or A8s and here they decided to add them as standard with a host of other stuff. I'll post a pic if I get round to cleaning all the cobwebs and eradicating the spiders in and around them :P
