Sky InsuranceVolks Autos
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    B6 S4 wheels over B5 S4 brakes - won't go?
    My latest acquisition, a '99 S4, has a problem. I can't fit wheels over the front brake calipers without fitting spacers.
    I would have thought that a set of 18" B6 S4 rims would have bolted straight over the 'standard' B5 S4 brakes. But, they sit on the face of the caliper without a spacer fitted, so I've had to space the fronts out... which I find strange.
    Here's a couple of pics I took, I apologise for the poor quality, but can anyone identify these brakes as standard or non-standard at all?
    And they're mounted on to this...
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    Basically, B5 S4 calipers are ****.
    They stick out about 7 feet from the disk, hence the problem.
    I'd fit some B6 S4 brakes, which is a nice upgrade and will fix it.
    Alternatively, some B7 A4's and C5 A6's/Allroads have a caliper thats the same as the B6 S4 ones in design, but mounts up with the standard B5 S4 disks, potentially cheaper that way.
    TD5 Land Rover Defender build
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    this happened to me! fitted b6 alloys no problem till i put new pads on then the same issue! 5mm spacers fix it till my rs4 b5's go on
    Audi S4 Black on Black. 1999(T)facelift, Aluminium Mirrors, KW Varient 3 coilovers, AmD remap, uprated D/V's, 315bhp375Lb/ft torque, milltek down, 100cpsi cats an back, S4 B6 18" Oem runnin toyo T1-R's. Rs4 B5 front brakes still to fit...
    "Stick a V8 in it!"
    15,350
    If your using spacers make sure you fit longer bolts.
    The stock bolts are only just long enough, and with a 5mm spacer the bolt only engages half way thru the hub.
    May 2010
    Bedford
    2,877
    Dont i know it! 3mm probably just about get away with it but 5mm use longer bolts or else you`ll be replacing a hub and having your wheel collapse inside your arch like i had!
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Don't worry. I've got longer bolts.
    PM me for more info
