AH FabricationsSky Insurance
Results 1 to 11 of 11
    Aug 2011
    16
    1.9TDI shaking - done the search thing but mine is a whole different ball game
    As per title my afn fwd is shaking as in you can feel the whole car going.
    It does it when on the move but not all the time. At 50mph it does it constantly but above or below this speed it just does it every now and then.
    There is no clicking which would indicate worn driveshafts and from looking a them, they seem fine.
    All bushes seem fine as there's no play in any of them.
    The engine is not skipping a beat (from what I can hear and the rev counter backs this up).
    The engine feels nice and smooth too
    Nothing to do with the brakes as they have all been replaced and the wheels bearings were all checked at the same time.
    Had vagcom put on it and no faults brought back
    Any ideas because this is driving me nuts.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,596
    rims or tyres? try swapping over the wheels with the rear ones or take it to garage and get a balance check on them.
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,235
    If it does it on idle then more likely the DMF is fooked. If it does it when on the move then you have a bent wheel or misshaped tyre.
    FOR SALE:
    Aug 2011
    16
    Examination yesterday. Downhill, in neutral with engine off. Still does it.
    Off to tyre shop in half an hour
    Aug 2011
    16
    Update. Old wheels were square. New wheels 16" genuine audi 5 spokes. £110 for five with tyres. Pleased with that. Fitted and balanced and still got the problem.
    Another check underneath has uncovered a sheered gearbox mount (the alloy part). Bodged for time being which is holding very firm. Still got the problem so clearly not this.
    All engine mounts look fine.
    I've been inspecting the shocks and the rear offside looks to be shot (leaking fluid). Surely it cant all be down to this can it????
    2,159
    When did you get the car? stunned it passed the MOT with these faults. I had rear rear shock failure my god that was interesting to drive the backend would bounce all over the place, would make for an even more interesting drive with a failed front shock!
    Aug 2011
    16
    The fronts and rear nearside look ok but your right b5nut, it makes for an interesting drive. Ideal for someone who works night shifts as it certainly keeps your awake!
    The MOT was in Feb but surely all these faults cant have just come on since then
    Have to admit it's got me totally demoralised and serioously contemplating getting shut of the audi. Not a nice return to the marque
    Aug 2011
    16
    UPDATE - Audi have said 2 days for them to receive a replacement gearbox mounting bracket (the alloy not the rubber) and that it has to be one for a AFN engine
    B0!!OX is what I have to say. Got one off a 20vt in local scrap yard for a fraction of the cost. Fits perfect and has the same part number
    Aug 2011
    16
    New gearbox mounting bracket and both mounts. Cured the crap gearshift sensation. Shaking problem still there so it has to be the rear offside shock. Got another one of those coming tomorrow so hopefully job sorted. Either that or I may be posting a video of my b5 burning :-(
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    You checked the engine mounts ??
    I snapped one clean in half right round the metal part and it shuddered like hell on my old 1.8 ADR.
    Just try lifting the engine on both sides if there shot it should lift the engine quite abit.
    Aug 2011
    16
    Got it!
    It seems it was a combination of engine mounts and the rear shock
