EM TuningJMB Retrofits
Results 1 to 11 of 11
    symun's Avatar
    Jun 2011
    Swansea
    147
    Anyone bought one of these....(central locking)
    or have experience of one....REMOTE KEYLESS ENTRY CENTRAL LOCKING KIT AUDI A3 A4 A6 | eBay
    I only have single key and drivers lock is getting a bit stiff......
    Cheers in advance......
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    gotta be worth a punt for £25. You've not lost much if it proves ****e really imo
    2000 1.8t quattro Sport totally standard (ish)
    CraigG's Avatar
    May 2008
    188
    Aragorn will be along shortly, he had one on his old FWD A4... been fitted a couple of years and still working fine
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    yeh, keys arent the best of quality and the flip mechanism has jammed open on both keys, although it lasted 18 months when we still had the car, so maybe the issue is my parents being hamfisted!
    TD5 Land Rover Defender build
    Oct 2009
    190
    Will a locksmith be able to just match your key, also was it hard to get wired up?
    symun's Avatar
    Jun 2011
    Swansea
    147
    would like to know how hard/easy it is to wire up.
    "Stick a V8 in it!"
    15,374
    I found it easy to wire in, but i have a fairly decent grasp of car electrics and all the wiring diagrams to hand.
    I know others have tried and struggled, but i'd think it shouldnt be too difficult to get the basics working.
    The keys can be tricky, and theres two things you need to do. You need to get the blade cut to match the car, which you can get a locksmith to do, or even your local supermarket key maker, that said, the two local places i tried couldnt do it, as the copy key wouldnt stay clamped in their vice properly.
    I ended up sending mine to a bloke that advertises on ebay, who cut them from a photo of the original key.
    You then need to transfer the immobiliser chip from your original key to the new fob. This bit requires some fiddling, as the chip is glued into the original key. I used a stanley knife to carefully slice away the plastic around the chip until i could release it from the glue.
    symun's Avatar
    Jun 2011
    Swansea
    147
    Cheers for the replies....i would only want the fob to open the doors. Not interested in getting the blades cut, although i know were i can get them done if needed.
    "Stick a V8 in it!"
    15,374
    In that case, goto Rclick.co.uk and buy the non-flip key version of the kit as the fob is much smaller:
    Rightclick
    Rightclick
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Re the key cutting:... I went to 3 branches of Timpsons to get a spare cut. One said it was 'dealer only' (coz he couldn't be arsed) The other two both said they could 'try' to do it but couldn't guarantee my key wouldn't fly out of the machine so I left it. I'll probably use the photo method when I find my camera again
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    I bought the exact same one for the Polo was very cheap feel si gave it back.
    I ended up buying the comfort unit and 2 keys from eBay worked out more but O.E
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
