My First Audi, my first VAGCOM scan, thoughts
madmax2
NULL
Hi guys, quick intro
defected from bmw to audi (long time bmw owner), managed to pick up a fairly nice B5 S4 2000 facelift but with old style badges, black outside /silver leather/carbon fibre combo in March and been loving it ever since. Been lurking and reading up on B5's since then and comparing notes...
Bought privately with two faults
1) airbag light on
2) oil pressure/temp sensor not working
3) (minor, DIS lines...hehe)
Scanned with VAGCOM today:
Please check my comments in bold to see if I am on the right path here..
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 551 D
Component: 2.7l V6/5VT 0002
Coding: 05711
Shop #: WSC 00209
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 04395
Shop #: WSC 06435
Address 08: Auto HVAC
Controller: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D57
Coding: 00061
Shop #: WSC 06325
Address 15: Airbags
Controller: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 01104
Shop #: WSC 06325
1 Fault Found:
01217 - Side Airbag Igniter: Driver Side (N199)
32-00 - Resistance too High
CONNECTOR UNDER DRIVER SEAT/DRIVER FOOTWELL?
Address 17: Instruments
Controller: 8D0 920 980 BX
Component: B5-KOMBIINSTR. VDO D07
Coding: 00464
Shop #: WSC 00209
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1173469
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to B+
29-10 - Short to Ground - Intermittent
SENSOR BY SUMP - MAKE SURE TO GET THE CORRECT ONE?
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 00209
6 Faults Found:
00991 - Interior Lights
28-00 - Short to B+
NO IDEA, INT. LIGHTS SEEM FINE
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
PREVIOUS OWNER ********?
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
49-00 - No Communications
ALARM UNIT IN RHS OF BOOT, FLAT BATTERY
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 00056
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00205
Shop #: WSC 06325
End --------------------------------------------------------------------------------------------------
BTW, I am in Ilford, Essex if someone needs something scanned :)
Airbag ones under seat just Disconnect with ignition of leave for 5 mins or so then reconnect should be ok clear the code before doing this and it should knock the light off.
Bear in mind that some of those codes could be years old. All depends on when the car was last scanned and the had the codes cleared. Best thing is to clear the codes and rescan in a week or so after the car has been driven.
Obviously, the air bag light on the dash and oil sensor is a current DTC. But the others could be old.
thanks for the info guys,
I cleared all codes yesterday, fixed the connector under the seat for Airbag light problem, went for my usual drives to and from work this today, rescanned
these are the only ones that remain
Coding: 00464
Shop #: WSC 00209
1 Fault Found:
Coding: 13130
Shop #: WSC 00209
1 Fault Found:
I've heard/read or the oil temp/press. sensor you have to get the correct one, it would be great if someone can confirm this either way.
By correct, I mean, not one form eurocarparts as apparently it wont work even though it is listed as correct...or rather, it works for some year models.
mine is a 2000 January and from VAGCOM deciphering the ECU is a d-box type.
Last question, how would I be able to tell if it has the original map or has been reflashed already? only on dyno?
6
798
6
926
I
21
