Monster MotorsportEM Tuning
    Mar 2010
    MARGATE, KENT
    35
    Knocking & rattling
    I've got an A4 B5 AVANT on a 1997 plate. The front end is knocking and rattling on uneven surfaces and seems to be getting worse. I mentioned this to a mechanic friend of mine when I had the off side front drive shaft replaced (the inner cv joint was broken and mangled up) he had a look at the suspension and subframe and said it was fine. It flew through MOT in JUNE with only one advisory of off side rear wheel bearing has a little play in it. Any ideas what it could be????
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,875
    I'd be giving your coil springs a once over as they can go at any given moment !
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,922
    Suspension arms, they can be a right Bugger for finding the one dudd one that's causing the problems
    Life begins at 140mph
    www.passionford.com
