EM TuningMonster Motorsport
    Jan 2004
    Northern New Jersey, USA
    91
    leaky washer fluid system
    when i top off my washer sluid system it takes about 5 days for the low indicator light to come on without me using the jets. hte system definately has a leak because i see puddles under the car sometimes. Anyone with similar problems? Any suggestions on prone leak spots or products to fix leaks?
    Mar 2004
    Cheshire
    922
    Re: leaky washer fluid system
    probably either the seal on the pump to the bottle or the hose has come off. see how far it actually leaks down to without using the pump and then you'll know where the leak is.
    Dec 2003
    n.ireland
    187
    could be a hose at the front of the washer bottle. i have had problems with it in the past .
    Olly__K
    http://www.audiworld.com/tech/misc28.shtml
    [img]/ubbthreads/images/graemlins/smile.gif[/img]
