Badger5Chris Nott
Results 1 to 9 of 9
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    60mm gauge in centre vents
    As per title, will a 60mm gauge fit into the centre vents or will it look stupidly big? Any pics?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    I reckon it will fit I've got a 52mm in mine and it looks fairly big
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Thanks Bradderz, does anyone know for sure?
    Nov 2010
    Scarborough
    103
    It'll look 8mm bigger than Bradderz'.Loads of room in a vent to fit a 60mm gauge.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    This is what i fitted on my S4, think it's 52mm though. Although, can't 100% remember.
    2002 2.5 V6 Quattro
    jcb
    Sep 2005
    uk
    4,077
    personally think it looks daft.
    it should be sunk in more, 60 mm will be a stretch if that is 52mm
    never really understood why people have boost gauges all over the dash. how often do you look at them and what for?
    its only useful if there is a problem
    Aug 2010
    3,136
    I had a look at mine and it looks as if there is around 6-8mm either side of the gauge to play with so I'd say it would be possible but will be a tight fit !!
    Mar 2011
    suffolk
    249
    Quote Originally Posted by jcb View Post
    mines mounted above the steering wheel in newsouths custom pod, not into all this hacking the vents about. i look at mine all the time lets you know if theres a problem before its serious also looks good !
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Thanks for the replies. Ive bought it now so if looks too big for the vent, ill have to look into other options. Its handy to know what you are boosting at especially when you are at a high state of tune
