JMB RetrofitsAH Fabrications
    imported_kbininger
    How Do Headlight Washers Work?
    I did not even know our A4 has headlight washers until someone stole the caps. How do they work? There is no mention of them in the owners manual!
    Thanks!
    Feb 2005
    Worthing, Sussex
    62
    Re: How Do Headlight Washers Work?
    Hehe not to worry m8, they do hide themselves well.
    i dont know technical stuff, but basically, if your headlights are on, and your pull the stick to wash your windscreen, then the little bits pop up out of the bumber just infront of the light, and squirt a jet of water at the light to blast the crap and grime off it. then they retract back so they sit flush with the surface of the bumper.
    JB.
    Oct 2004
    Southampton, England
    86
    usually they use pressure from the washer pump to push them up and spray, some uses small motors but not very often,
