Volks AutosJMB Retrofits
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    prefacelift Xenon lights into facelifts
    As per the title. I have a pre facelift S4 with Xenon lights and want to know if its possible to take all the bits off my lights and add them to non xenon facelift lights?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    I'd say you could do it even if it ain't a straight swap !?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    The projectors are quite a different design, as the two lamp units are made by different manufacturers.
    Possible perhaps with some fabrication, but i doubt its going to be worth it
    TD5 Land Rover Defender build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    i wont bother then. Ill have to hunt down a xenon set o facelifts
