Monster MotorsportEM Tuning
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    Throttle Body DTC that wont clear?!?!
    Just been playing with car so though i'd scan to see if my Lambda's had thrown a fault again. They HAVE! So going to buy two new ones.
    Here is list of codes. Any help would be appreciated.
    Software Coding: 04201
    Work Shop Code: WSC 00020
    4 Faults Found:
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 -- 35-10 - - - Intermittent
    16539 - Oxygen (Lambda) Sensor B2 S1; Heating Circuit: Malfunction
    P0155 -- 35-10 - - - Intermittent
    17980 - Left Engine Mount Solenoid Valve (N144): Short to Ground
    P1572 -- 35-00 - -
    17977 - Cruise Control Switch (E45): Implausible Signal
    P1569 -- 35-00 - -
    17967 - Throttle Body (J338): Fault in basic settings
    P1559 -- 35-00 - -
    I was expecting the P0134 & P0155 to be back on. But the latter three are all new to me. I Dont even have cruise control so why that has come up i'll never know!! But possibly related to the throttle body?
    I've cleared all the codes, but the last one, P1559, STAYS ON all the time! I've done a throttle body adaption but still no joy in clearing the code!?
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    AndyC's Avatar
    Apr 2003
    Dorset
    711
    perhaps time for a new body.
    more than likely a discrepancy between the two internal tracks so it cant properly calculate its position
    there is no such thing as bad weather, just the wrong clothes!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    try taking the black cover off the side and cleaning the tracks?
    Engine mount thing is odd, i didnt think B5's got active mounts.
    TD5 Land Rover Defender build
    S4_dan's Avatar
    Jan 2006
    1,504
    Right, Cleared the above codes (not cleaned anything yet) on the day i posted the above. Scanned the car again today and now I have only the P1559 throttle body basic settings. So next task will be to check the tracks and clean throttle body.
    I have however ordered 2 x FAE Lambda sensors for the car from ECP seeing as they have a generous 25% discount going on at the moment. I know the sensors haven't thrown a code up today but they have both thrown faults in the past and, albeit, I have driven the car stupidly hard over last three days (love these roads round here....private of course!!) So i'm going to replace them anyway.
    Is the throttle body difficult to remove? Can't remember from when i rebuilt the engine. Or can I remove the black plastic piece while TB in situ?
    Dan
    2002 2.5 V6 Quattro
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Hi, I had the same problem on my 1.8T with the basic settings code. It all started when I had a faulty coil pack. When I scanned for error codes the fault in basic settings kept coming up, and I assumed my problem was to do with a throttle body problem.
    To cut a long story short I ended up fitting 2 other throttle bodies without getting the fault code to clear, checked all the wiring, voltages and everything was as it should be. When I fixed the coil pack (which didn't register a fault code because the early type of coil doesn't register a fault code!) The car ran perfectly for the next 2 years with the fault in basic settings code still present. I am guessing that this fault code was there long before I had an issue with the coil pack. So my advice would be to sort out your other issues first and you may find the throttle body problem isn't a problem at all.
    S4_dan's Avatar
    Jan 2006
    1,504
    My car does run fine. Well, slight hesitation at low revs (1k - 1800k rpm) then is fine. I would of thought if it was a coil pack, the hestation would be right throughout the rev range?
    Leads will be next thing to get changed.
    I'll do some resistance checks on the coils and see what is occurring.
    2002 2.5 V6 Quattro
