Sky InsuranceChris Nott
Results 1 to 8 of 8
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Facelift rear lights, plug and play?
    As per the title, im going to fit some face lift rear lights to my 99 S4 avant tomorrow. Im sure ive seen mention of swapping pins over etc? Will they just plug in and work or do i need to swap pins about? Details of which pins would be good if that is the case as im strapped for time tomorrow
    thanks ..lee
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    I would assume you will need to do the pin swap in the plugs like you do with the saloon.
    If the same the swaps are
    O/S - Swap Blue/Red with Black/White
    N/S - Swap Blue/Red with Black/Green
    Life begins at 140mph
    www.passionford.com
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by Oranoco View Post
    thanks mate, which lights is it that needs swapping over? my reverse looks in the same place. im sure i'll work it out when i actually look at it but all the info's good so i can get it done quick
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    That's for saloon, double check before changing any wires. I've only performed the swap on my current one, never bothered on my old avant
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Avants are a streight swap.
    I might be interested in your old lights if they're in good nick.
    TD5 Land Rover Defender build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Pretty sure they are perfect. Ill get them off after work and take a look
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Well that was easy
    before
    After
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Oh and a pic for you Aragorn
    They are nigh on perfect. Open to offers, not looking for much
