Results 1 to 13 of 13
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    aluminium flywheel
    right im in process of looking for a solid flywheel and clutch now i have found this flywheel for a resonable price with delivery it works out at around £150 before import duties and tax and it describes it is to take a 240mm S4/RS4 clutch so i was thinking order this then source a clutch from ECP or ebay or somewhere else and it should work out at alot less than the ecs stage 1 steel FW and Clutch which would work out around the £600 mark but this one is aluminium and 2.8lb lighter but is 3.6lb heavier than the ecs aluminium one but im not to bothered about the wieght i just want to go solid and my question is, if i went with this flywheel would it take any S4 Clutch ?
    heres the link - SPEC Aluminum Flywheel - UltraRev.com - Part# SA01AB
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    It will take any S4 clutch, but that thing you've linked to isnt right.
    I suspect its a replacement friction disk for the alloy flywheel, or an order code to convert a kit with steel flywheel into aluminium, because the flywheel itself is $499
    TD5 Land Rover Defender build
    Oct 2009
    Melb, Aust
    48
    Spec make quality stuff.
    034 motorsport sell them.
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    Aug 2010
    3,113
    new it was to good to be true lol may just have to stick with the ECS one then unless i find one in the UK or cheaper !! its just import duties and tax i cant be arsed paying its daylight robbery !!
    May 2010
    Bedford
    2,877
    Then do the S2/solid fly conversion and get the fly lightened (which i wish i had done) Mine finally gets fitted on wednesday. 7 months after getting it machined
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    15,317
    I didnt bother lightening mine either. Makes it easier to drive with a standard weight flywheel anyway.
    I did slightly worry that i didnt balance the assembly, but then the clutch parts arent balanced either so hopefully it wont matter!
    Aug 2010
    3,113
    Found this one on ECS tuning Audi B5 A4 Quattro 1.8T > Drivetrain > Clutch > ES#1396 Lightweight Flywheel Kit - B5A4AEBFLWFKT
    May go with this over the steel kit and just source the clutch back here presuming it takes an S4 clutch that is or do all the aftermarket ones take S4 clutches ?
    "Stick a V8 in it!"
    15,317
    Thats a lwfw that takes a standard sized 228mm clutch, not a 240mm one...
    ECS's 240mm conversion uses a standard S4 clutch, but some other companies use bespoke parts.
    Aug 2010
    3,113
    Damn . . . I just can't win lol
    Looks like ill just stop looking around, shut up and get the ECS RA4 stage 1 kit and have done with it lol
    Is there no uk based company's that do a flywheel to take a S4 clutch ??
    "Stick a V8 in it!"
    15,317
    TTV-Racing do one.
    Aug 2010
    3,113
    TTV-Racing do one.
    Got a quote yesterday for there flywheel to take a 240mm S4 clutch £291 Inc delivery so I think I'm going to go for this and then buy either a Luk or Sachs or valeo clutch kit.
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by bmarshall View Post
    not the best judge of quality. 034 sell everything
    Spec do not make "quality stuff" just google spec failures and see how many people have ripped the friction lining off their fly wheel, had the rivets pop out, had the springs on the friction plate come out, had the spring on the pressure plate fail.
    I spoke to AMD years ago and he laughed when I asked him about Spec flywheels and clutches. he had just removed two from high boost turboed cars and they were in pieces on the floor of the garage.
    I have a TTV steel flywheel with a Southbend clutch attached to it.
    I also have a Southbend on a stock flywheel which has seen the best part of 120k and some abuse at my hands which does not appear to be giving up just yet
    May 2010
    Bedford
    2,877
    Ive had set up fitted finally. Its about the same weight of the standard set up but as i mentioned you could easily get it lightened. Feels great as it is. Pedal is quite light and the biting point is in the middle at the minute not at the top where it was. releasing it is a lot sharper than before. Just waiting until the bedding in process is complete and then i`ll give it some abuse and see how it gets on.
