EM TuningBadger5
    Biodiesel Purrrr
    Jun 2011
    London
    150
    removing side/sill trim for amp wiring
    Hi all,
    tried pulling the side/sill trim (interior) off to rum amp wireing down there but could not get in there,
    the plastic bits just seemed stuck on!
    I had the front kick panel unscrewed and removed,
    can't find other screws -
    does it just clip on?
    [1998 Avant]
    cheers, P)
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    yea IIRC you need to carefully pull up it will be tight
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    I found I didn't have to remove that trim. I managed just to squeeze the wires up underneath it between it and the carpet
    2000 1.8t quattro Sport totally standard (ish)
    Oct 2009
    Melb, Aust
    48
    Get a big flat screwdriver in there, its clipped on.
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
