I
imported_GezzerS4
Having spent weeks gathering all the parts needed for install, thought I would do it this weekend, Big Mistake
Ripped out old unit, fitted new Double Din cage, Surgery needed but was prepared for that.
Now the Problems
1. New Climate Control Flashes display for about 3 mins, VAG-COM fault of "Initial Set up not Performed" so I need to find out how to do that, and it reverts to 22c when you turn off the ignition !!!.
2. Wiring - All the instructions tell you to remove the Can Bus Low & High - Pins7 & 12 from the Symphony 20 pin connector and connect them to the TMC Connector and then back to NAvPLus 26 Pin Connector, great if you have Can Bus wires in your original 20 pin connector, Why hav'nt I, every instruction I have seen has them in, result TMC not working, no data presumably, anybody any ideas on where I can pick up the CanBus feeds from or seen this before.
3. Original Ashtray Does not fit - Too ******* Wide, need to find the right one now, Grrrrrrrrrr.
And I hav'nt even started on the TV Tuner Yet!! /ubbthreads/images/graemlins/bang.gif
Apart from that, it looks good and works a treat
Now the Problems
