Monster MotorsportChris Nott
Results 1 to 30 of 30
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Inexplicable coolant loss???
    Im losing coolant from somewhere (fill it on Mon morning, by the end of the week it's down to min. Has dropped so far at occasionally that the DIS warning comes on).... no idea where to start looking though.
    • HVAC works great hot and cold.
    • Coolant temp never above 90, and doesnt move...
    • No apparent leaks
    • No white smoke/steam
    any suggestions where to start looking?
    Car is a 1.8T APU, and G12 is getting expensive with the amount ive gone through
    (on a side note also, how much oil should a 1.8T go through/lose?)
    Currently rolling in a SKODA!!!
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,936
    Check the plastic pipe at the back of the engine and for signs of leaking on top of the gearbox
    Life begins at 140mph
    www.passionford.com
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    How's your carpets?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    1,892
    Have you checked the expansion tank overflow? I had the similar fault on my TDi and it turned out to be he head gasket, exaust gasses going into the coolant system and it was being chuck out the expansion tank.
    Arrkon's Avatar
    Oct 2010
    1,633
    Carpets, bone dry. Gearbox was out only a few weeks back to do the clutch conversion, no obvious signs on or around that. Expansion tank "overflow" I've not looked at, will check that when I get a chance. Though the header doesn't smell "exhausty" even after a thrashing, just smells of g12 lol
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,889
    Easy way to check is get someone to use an emissions tester over the header tank that will rule out the headgasket.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Sep 2008
    177
    Quote Originally Posted by Rconn View Post
    • No apparent leaks
    I presume you have your under tray on have you checked to see if that is full of water or any water in it lowest point and all that..
    That amount must be visible and going somewhere..
    Aug 2010
    2,889
    Also check for a pink crusty residue of coolant on the system also near the water pump and at the oil cooler pipes !
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    I had this on my S3, put some red food colouring into your coolant, go for a drive, then pull you plugs out one at a time. If the ceramic on any of the plugs has turned pink then you may possibly have a hairline crack on the cylinder head.
    Or like Bradderz says, hydrocarbon test the coolant
    salad.dodger's Avatar
    May 2011
    Berkshire
    68
    I had coolant lose on a 5 series BMW, works out the head was leaking right at the back, could see water marks
    1,892
    A very easy test to check if your getting exhaust gasses into the coolant system would be to take it for a quick drive and get the engine almost upto temp and check the hoses for pressure, if they are solid then gasses are getting into the coolant system, and you are looking at either a HG failure or damage to the cylinder head.
    The top water hose on my car was just about solid even after a quick drive and the engine was around 80 on temp.
    One other possible cause is the expension cap has failed and needs to be replaced, a quick pressure test would answer that question or just get one from a breakers for a couple of quid.
    Arrkon's Avatar
    Oct 2010
    1,633
    Ah well i have just squeezed the hoses and they are still quite soft so hopefully not a HG problem
    TDIPOWARRR
    Jul 2010
    618
    Leaking from a Core plug maybe?
    Jul 2007
    766
    Take off the header tank and check at the back for acrack.This is where we found a leak and the new tank was £12
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by Jacktdi View Post
    How do you mean a "core plug" ?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Round metal disk pushed in to the side of the engine. It Blocks up the old holes used during the manufacturing process.
    They can become thin and leak (happened on my land rover) or fall out.
    Oct 2009
    Melb, Aust
    48
    Welsh plug
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    Arrkon's Avatar
    Oct 2010
    1,633
    After having a good look, i may have found the issue...
    Take a peek at the pics on FLICKR and tell me what you think... its like a pinky white sticky paste.... could be some coolant residue?
    Cheers guys...
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Yup, I'd say thats coolant.
    Arrkon's Avatar
    Oct 2010
    1,633
    thought so... have added a diagram of the area with positions i think the leak may be coming from... any ideas? I suspect No 3 is at fault... or hopefully duff pipes...
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    it looks like its coming from coolant pipes on number 14 of your diagram.
    Possible a split pipe or the metal pipe work in side has rotted away.
    I'd take the coolant pipes off, give the area a good old clean, replace the spring clips and try again.
    Arrkon's Avatar
    Oct 2010
    1,633
    yup was thinkin that... Cheap fixes win
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Deffo.
    I just need to find out where my coolant smell is coming from now.
    I'm off to check my oil filter housing.
    Arrkon's Avatar
    Oct 2010
    1,633
    if its strong interior smell. could be the HVAC exchanger.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    I do hope you don't mean this
    Arrkon's Avatar
    Oct 2010
    1,633
    yep thats what i meant... is that pic yours???
  28. #27
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    Nahh Google image.
    I hope its not.
    I really don't want to take my days out.
  29. #28
    Arrkon's Avatar
    Oct 2010
    1,633
    Days? Did you mean dash??? Haha
  30. #29
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    LOL.
    Yeah Dash.
    The fact that it only smells when it pumps out warm air has me even more worried now.
    Know of any other way to check it?
    All my carpets are dry.
  31. #30
    Arrkon's Avatar
    Oct 2010
    1,633
    Pressure test maybe?
