AH FabricationsChris Nott
Results 1 to 9 of 9
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    1.8T APU Engine starting issues
    My mate has just bought an Audi with the APU lump in it. 99% percent of the time it starts first time with no problem.
    THen occassionally, when he goes to start it, it will just crank and crank. After about 15/16 attempts, it will start but sounds like its misfiring like mad, puff of dark blue/black smoke and then after about 20seconds runs on all four fine and dandy with no smoke. And will continue like this for a days/weeks, until it decides not to start.
    He has changed the plugs, leads look new and doesnt have any other running issue once up n running.
    Nothing is coming up when i scan with VCDS (Although not tried it whilst the car struggles to start the car)
    Is this something common? Anyone else had a same/similar issue?
    Car always starts in the end, just takes alot of time sometimes before it does!
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Quote Originally Posted by S4_dan View Post
    Cheers,
    Dan
    Could this be an IMMO issue? if the car doesn't recognise the key, then i think it will still fuel and turn over, but not fire. thus you'd get rough running, smoke and missfire as it would be burning excess fuel that the ECU hasnt got the adequate metered air for... Just a thought.
    Currently rolling in a SKODA!!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    +1 with rconn more than likely be the IMMO and its still fuelling, they can be very intermittent mine hasn't done it for around 6 months and has been fine upto now touch wood lol
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    S4_dan's Avatar
    Jan 2006
    1,503
    If it was the immo, wouldn't the key light on the dash flash or something?
    2002 2.5 V6 Quattro
    Aug 2010
    2,866
    It should in theory yes mine did, also I'd be checking it with vagcom as it should throw a intermittent fault with the key or something else I'd also check the ICM as they have a tendency to give up now and again.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    immo will let the engine start then shut it down after a second or so, it will also log a fault code, and flash the immo light, so its not that!
    TD5 Land Rover Defender build
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Does this engine have a cold start injector?
    2000 1.8t quattro Sport totally standard (ish)
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,001,880
    Follow Administrators On Twitter
    Sounds like the water temp sensor might be a little out. If the car thinks it -50degs it will over fuel on start up. Also check the ambient air temp as it will have the same effect.
    Best of luck
    S4_dan's Avatar
    Jan 2006
    1,503
    I'll do a resistance check on the water temp sensor when he comes round next.
    Ambient air temp sensor? Is that the sensor that shows up the temp on the DIS? Or is it a different sensor?
    2002 2.5 V6 Quattro
