Sky InsuranceChris Nott
Results 1 to 14 of 14
    Jun 2011
    bristol
    63
    Standard or not 1.8 t
    Hi peeps ive got a 96 1.8 t AEB not sure if it is standard cuz it goes really well if u no wot i mean the boosting side of things is 1000 rpm to 3000 it spikes at 9/10 psi and 4000 rpm to 6500 it boost 6/7 but I will do well over 140 mph is this right 4 standard how will I now if It's been chipped or remaped don't now if any can understand wot I mean lol
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    iirc standard boost is 7psi. Mine is chipped and peaks and holds 10-12psi for 181bhp and a top speed of *70mph* on the speedo then it seems to hit a wall.
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    The book indicates a top speed of 135mph for a stock 1.8T FWD.
    The speedo does overread though, so an indicated 140-145 seems about right.
    I'd say your boost figures sound standard.
    TD5 Land Rover Defender build
    Nov 2010
    Scarborough
    103
    If it's a 96 AEB and it has been remapped then it'll have had a physical chip change as you can't remap them through the obd port.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    Jun 2011
    bristol
    63
    Wicked cheers can I open the ECU and have a look if there's a different chip
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Yep
    2000 1.8t quattro Sport totally standard (ish)
    Jun 2011
    bristol
    63
    would the chip have a name I.E super chips or something like that
    Oct 2009
    Melb, Aust
    48
    I have a 96 with a chip that boosts to 12-14psi, the chip is not labled though.
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    Jun 2011
    bristol
    63
    kk cheers ill have a look c wots goin on
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    This is my chipped ecu. You can see the large chip rased on a 'piggy back' at the bottom of the board, On a standard ecu there is just a small chip soldered to the board itself. My ecu was like this when I bought the car and there is nothing to indicate who's chip it is. I don't know if there is a way to find out because I'd be interested too!
    Jun 2011
    bristol
    63
    can i have a look when the ecu is on the car or do i have to take i off if so will i need vag com to set it back up
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    No you won't need to set it back up but you will have to remove it from the car because it is inside a metal case. There's only 2 plugs connect it to the car. Just ull the tabs on the side of the plugs and they pull out. 4 Torx screws secure the board in the case but can't remember the size sorry
    Oct 2009
    Melb, Aust
    48
    Quote Originally Posted by 20va4 View Post
    The 96 square ecu has 5 small coloured plugs.
    96 A4 1.8TQ
    'TO COME'
    Jun 2011
    bristol
    63
    kk cheers
