Hi all new to the site I have a b5 and just done the one piece headlight conversion. All went well had the connecters for the new headlights and all the wires were the same colour so cut the old connectors off and soldered the new ones on. Only problem is that the passenger side main beam isn't working. I have swopped the bulbs over and full beam works using both bulbs so the bulb is fine, checked the fuse 5amp that is fine auto adjusts work side light works along with full beam. Also tried grounding the bulb with a separate wire still no joy. Anyone every had this problem or is there something that I could of missed. Any help would be appreciated.
Cheers paul
Cheers paul
