AH FabricationsJMB Retrofits
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Door Removal Question
    hi,I will be changing the doors soon,and wondered which would be the best way to go about the wiring loom.The replacement doors have had the wiring removed,so is it easier to remove the door and leave the loom attached to the car,or unplug the loom in the footwell and remove from the door one off?
    thanks in advance
    tony
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I'd take loom off the car still on the door then swap everything over whilst off the car !
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    guessing its a front door?
    if so pull it out of existing door and leave it hanging untill you loosly fit new one then put through
    its a right pain to undo all the plugs in footwell and feed them out then back in
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    thanks for the replies.
    it's all 4 doors that I am changing.I think I'll leave the wiring attached to the car.
    tony
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Ive recently changed all 4 doors and i left wiring attached to car. A very simple job actually
