JMB RetrofitsChris Nott
    Mar 2011
    suffolk
    249
    ac fault finding
    ive just had my ac re gased as was not working and no sign of leaks, but when picked car up he says there was 690g of gas still in there and only meant to hold 760g so was more than enough to kick in ?????
    now i no thers no leaks im stuck why it don t work
    if i press the ac button the engine note definetly changes so i presume the clutch on the compressor is good ( thank god)
    is there any test i can do myself on ac unit etc or is it a case of throwing money and ope something sticks lol
    thinking ac pressure switch but can i check 1st????
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    If the pressure switch was shot, the compressor wouldnt kick in.
    Have you actually looked at the compressor to see if the centre spins when you press the switch? (ie the clutch works..) as some systems increase the revs at idle so as to compensate for the extra load.
    Currently rolling in a SKODA!!!
    Mar 2011
    suffolk
    249
    i havent yet mate i cant bare to take the front off again lol
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    When the econ light is lit it means the air con is off ie for economy running. So when it's not lit the a/c should actually be on !
    Arrkon's Avatar
    Oct 2010
    1,641
    Quote Originally Posted by tangerinedream View Post
    dont need to. you can look down from the engine bay and see it
