JMB RetrofitsAH Fabrications
Page 1 of 2 12 LastLast
Results 1 to 40 of 62
Like Tree3Likes
Thread: A4 B5 Cruise Control Retrofit Instructions with pictures
    Jan 2011
    Aberdeenshire
    646
    I decided to retrofit my A4 B5 ".5TDi Quattro with cruise control, as the wife's already had and I felt left out.
    I bought the Kufatech loom KUFATEC GmbH & Co. KG - Kabelsatz GRA Audi A4 B5 30096, for £18 plus delivery and VAT, coming to £27 all in. I had to wait whilst they made the loom up. I got the stalk from All Audi, for about £25.
    Once all my parts arrived, I started work.
    First I DISCONNECTED THE BATTERY - there is work on the fusebox - then I removed the steering wheel, stalks,and dashboard for access, There is plenty of info around on how to do this, so I wont lay it out here.
    Next, under the bonnet, I accessed and removed the engine ECU.
    Notice I did not have to remove the Scuttle around the wipers - I removed the screws with a 1/4" ratchet and 8mm socket. It was a little fiddly, but not hard. This accessed the 'White Connector' mentioned in all the help guides.
    I then removed the ECU and the ECU box, for access
    I then removed the 2 screws to release the connector block.
    Next, I fed the loom and block of connectors through the footwell so I could release the connector, the picture shows the release tags
    and the view from the footwell
    I then fed the loom down through the column and footwell
    leaving it unsecured at the moment (unlike the picture), so I could fit the pins
    The connector is in two parts, and only on side is needed. The two parts are locked together with a clip.
    Then the pins are accessed by sliding out the top part of the connector, agian secured with a clip. The pictures show the pin numbers, as the connectors are not marked.
    For those who are interested, for orientation, the pin numbers/colours are as follows: Pin 6 is Brown and Green
    Pin 7 is Red and Green
    Pin 8 is Blue
    Pin 9 is Red and Yellow
    There is a blank space with no pin
    Pin 10 is Black and White
    Pin 11 is Black and Red
    The loom has pin numbers printed along it, with the power wire being seperate., from the main ECU loom The pins just push into the connector. Make sure they are the right way around first, as I did not have to remove any, so I don't know how they lock in.
    Refit the connector lock, and clip the two halves together
    put it back in the block and refit the block and the rest of the ECU parts.
    I then removed the fusebox for access, and fed the power supply wire into it, an spliced it into the wire off Fuse 31, which the owners manual lists as the Cruise Control fuse.
    Note I used a proper environmental splice (bought from Maplins HeatShrinkable Cable Splicers : Crimp Terminals : Maplin ), not a crappy Halfords red butt splice, nor did I solder it. This will guard against future connection problems.
    I then secured the loom with tyraps alomg the existing looms
    Then it was a case of refit dash, fit the stalks back onto the column
    and refit the wheel.
    The next step is to encode the ECU via VCDS, Select 01 Engine
    Select 11 Login
    Login code is 11463 to activate
    Robert is your fathers brother.
    If you want to test it via VCDS,Select 01 Engine
    Select 08 Measuring Blocks
    Zone 4 should NOT read 255 (CC deactivated)
    Zone 3 bits should all be '0' with CC off. On, Set, Resume, Brake on and Clutch on all show as bit '1'
    Finally, a road test is always good, the owners manual gives the funtions available.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    i have cruise on mine, i paid £250 about 8 years ago
    Thats a pretty good guide and price you paid well done!
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Nov 2010
    Scarborough
    103
    Excellent write up! I've a slightly off topic question though.Those Maplin connectors.What tool is used to fit them? Be perfect for fitting facelift headlight connectors to non face lift loom.
    Thanks.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    Nov 2010
    Scarborough
    103
    It's ok.Found it on the full Maplin site.Was looking on the mobile one initially.
    Things to do:
    Sell it :-(
    Jan 2011
    Aberdeenshire
    646
    Bog standard ratchet crimps (Red,Blue,Yellow) and shrink the heat shrink with a hot air gun
    (The back of a soldering iron if you are rough!)
    They seal with adhesive, so prevent water ingress.
    Dec 2011
    I just signed up to this forum to say thanks to PAULF. I just fitted cruise control to my A4 and without this write it wouldn't have been possible. The pictures showing where to insert the pins to the ECU plug were particularly useful.
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    any one know the part number for the cruise control stalk?
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Jan 2012
    Malton
    279
    I have one James! Out of my old 2.5 tdi Q.
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un. Quality Cambelt kit fitted - next on list is control arm set.
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP - but she lives on in the many,many donor parts she gave so that others may live...
    Jan 2012
    Malton
    279
    And you really want an auto dimming mirror too....
    Jan 2012
    Malton
    279
    But surely your 1.9tdi Q will have both already as a Quatrro?
    jbh
    jbh's Avatar
    TDi lover
    704
    sadly it doesnt have either.. pm me details Tom
    yea my quattro was the poor mans spec... its not even got climate control and didint have a centre armrest either!!
    Dec 2013
    mid devon
    52
    Add jaffaxr on Facebook Add jaffaxr on Google+
    quick question does this work with an early model with a throttle cable?
    nice thread all i need now is a good mech to fit it all for me when ive got the bits...
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    This is for DBW only.
    For the cable you need a few more bits.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Dec 2013
    mid devon
    52
    Quote Originally Posted by ScottD3 View Post
    does anybody know what extra bits i would need?
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Aragorn and possible Byzan has done this before.
    I'm not sure what bits are needed.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    There is an actuatator, rod and bracket needed, the rod connects on the ball joint on the throttle valve control. I think it works similarly to the turbo actuator
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Aug 2013
    The 'carse of Gowrie.
    121
    Damn! I really [YES] miss cruise on my car, got so used to it before, some people might decry it but setting your speed to "the limit" and cruising along whilst letting all the fast guys plooter ahead and find the cops/cameras keeps your scrap of paper with no more ink on it!!
    Thats the way it is these days for 90% of your journeys today I'm afraid...
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    I would love to fit cruise to my car, it's DBW, so not such a problem.
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Thought I'd just bump this back up as I'm interested in fitting Cruise onto my AEB engine. Any ideas on what's needed at the engine end and how available it is?
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    Jan 2011
    279
    Ahh, not a problem was a slight oversight... The plug pins are different coloured to the ones I had on my car.
    Maybe it's my fault, I didn't have quite enough time to do much more than run the wires from the grey loom.
    I only checked the wiring on the 'plugs' to the 'sockets' which were left attached to the car under the ECU.
    Are the wires in the 'sockets' different to the 'plugs' in colour?
    One last thing, there's a short loom from the CC stalk, which plugs into the grey loom.... Where is that meant to hide? I messed about for ages trying to find a suitable place in the cowling.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    I don't know bout the cable.
    I sent what I used, I got no idea on others. Sorry.
    That little length with the plug is meant to clip in to the stalk but it don't, i just taped it up to the loom out of the way and it's been fine.
    Jan 2011
    279
    That's what I did, just squeezed it into the gap below the ignition barrel wiring, seems ok.
    Was it wired into the bottom of the sockets as opposed to the actual plugs, Scott? I ran the wires up to the ECU box, but the plugs have different colours to what you sent me... Aarrgghh
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    I joined them to the cables.
    No idea why they changed colours. Could be a year thing?
    I think the pin outs would be the same.
    Jan 2011
    279
    Scott, do you have a wiring diagram? I think I'll go to the scrappy see what's up there
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    I don't sorry mate.
    I got my info from the CC threads dotted about.
    2,185
    Anyone got the part number of the 6 pin plug that goes onto cruse control arm assembly, as I cannot see it in etka.
  28. #27
    Jan 2011
    279
    I've been up to the scrappy, Scott. Hacked off a white plug and socket to have a better look.
    9 pins in socket, 13 in plug to ECU. Much easier to see how now.
    I can follow the instructions on here. Going to break the new socket apart to get the pins out then solder them to the loom I got from you.
    B5NUT, I'm getting a nice steering wheel off the car in the scrappy, same as I have but not worn smooth yet.
    When I'm changing it I'll take the cowling off and get the part number for you, might be easier to solder the pins onto the loom with it out of the car.
  29. #28
    2,185
    Cheers, I've got the pins, just need the part number off the cruise control harness, it should one the one you got from Scott.
  30. #29
    Jan 2011
    279
    Yeah, that's the one. Could be next week before I get into it, on night shift this week, lots going on with planning for house extension, trades coming to give quotes, kids swimming lessons, and school sports on Friday... Trying to get more than 5 hours kip is a joke this week lol.
  31. #30
    Jan 2011
    279
    Scott, I got the correct white plug off a scrapped (and I'm having quite a few other bits off it) black A4 FL in the scrappy. I have the perfect tool for removing the pins from the sockets so I can solder the pins to the loom I got from you. The tool is.... SIM removal tool for an iPhone, push it up from underneath and it shifts the wee catch, pin comes straight out, no problem
  32. #31
    2,185
    What colour interior does the car have in the scrap yard?
  33. #32
    Jan 2011
    279
    It's a black cloth, got plain black bolsters and check type panels.
    The drivers seat has a tiny cigarette burn.
    It's the same cloth as mine but a saloon. I was thinking about the rear seat base tho as kids seats have damaged the fabric
  34. #33
    2,185
    Long shot be could you check to see if it has the ISOfix brackets. Was looking for a facelift with the gray plastics some of mine are damaged.
  35. #34
    Jan 2011
    279
    I'll pull the seat up and have a look, it didn't look like it at first glance. It was a bit tight for space... Was going to take the rear offside door trim off that car as mine rotted and got pulled off lol.
    If I had somewhere to store the whole car I'd buy it, same colour, trims, material, alloys, carpets, centre arm rest (better condition than mine) I could go to town with that car
  36. #35
    2,185
    Cheers, not sure why but isofix does not look like a common option, and the same brackets were used on the A4 B5, A6 C5, Passat 1997 to 2005 & skoda Superb 2002 to 2008. Yet I cannot find any on ebay or local breakers and I'm not paying £120 Audi prices.
  37. #36
    Jan 2011
    279
    There's at least one Passat in Perth scrappy.
    It will be next week before I can go up, Tuesday morning most likely.
    I'll have a look and see what I can find.
    B5NUT likes this.
  38. #37
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    Quote Originally Posted by B5NUT View Post
    Do you need both sides? If not try this on eBay 131142983240
    If you do need both it's the same as going to audi
  39. #38
    Jun 2014
    Quote Originally Posted by PAULF View Post
    Thanks for the guide.
    You forgot to add that you have to open 066 measuring block group
  40. #39
    Jan 2011
    279
    Hooked the car up to VCDS, can't get the cruise to switch on.. Tried the info on here and no joy
  41. #40
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    What did you do on VCDS?
    did you code it?
