Volks AutosSky Insurance
    Dec 2006
    131
    aeb oil leak, picture request
    hi, ive got quite a bad leak on my AEB and after an hour of cleaning the only place i hadn't got at was behind the timing covers. so after pulling the covers off i noticed the gasket behind the sealing flange directly behind the crank pulley didn't look right, as in it did not follow the shape of the flange,
    its number 17 in the bottom picture here
    i could do with a bigger picture like this
    to see if the gasket should be hidden behind the flange or stick out at the top all over the place like mine does
    thanks
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,876
    Only one I could find it could be the seal behind the toothed pulley maybe ??
    http://i889.photobucket.com/albums/a...K/P3070016.jpg
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Dec 2006
    131
    cheers bradderz looks like thats my issue, this is how mine looks (sorry bout using paint haha)
    looks like ill be fitting a timing belt kit sooner than i wanted too
