Right before I get round to fitting the FT I would like some answers on a couple of questions.
So,
1. I'm going to drain the coolant when I remove the front end, is there any bleed screws on the cooling system or is it a case of taking the expansion tank cap off and reving it up for 10 mins.
2. Is there any other gaskets I need other than these gaskets ? - exh manifold, turbo to manifold, turbo to cat, oil return (is there one either end of pipe?) have I missed anything ? Also list of part numbers if pos please.
3. Also going to change my fuel filter what washers do I need? part numbers please.
4. When charging the turbo with oil (will be new oil with a new filter) with the ICM disconnected how long cranking ... 5 secs ?
And anything I may need to know when replacing it with it being my first Audi.
So,
