Chris NottEM Tuning
Thread: n75 problem
    Jun 2011
    bristol
    63
    n75 problem
    hi peeps i seen on here that u can adjust the screw on the n75 so i done it and now it dont adjust now getin 4 psi with it unpluged and plug in does it mean it is f**ked
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    I'd say so yes, did you do it half a turn anticlockwise ??
    Jun 2011
    bristol
    63
    Ya done that and now it's really Easy to turn and don't make a different to the boost
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,093
    Sounds like the screw has broken apart, can happen. It's a sad risk you take when performing the procedure
    Life begins at 140mph
    www.passionford.com
    Jun 2011
    bristol
    63
    Ya I now thought I'd try it and c wot happens lol
