AH FabricationsChris Nott
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By aragorn
Thread: hid upgrade problem
    mad cornish pastie's Avatar
    Audi novice handle with care
    Oct 2010
    cornwall
    83
    hid upgrade problem
    i have put a hid kit in, but the beam only goes about 4 to 5 feet but the full beam is fine, so i'm thinking if i raise the headlights that'll throw the full beam out, any help appreciated
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    Are they facelift headlamps?
    TD5 Land Rover Defender build
    Oct 2010
    cornwall
    83
    yes they are..
    iv'e searched on here but can't find anything, apart from warning lights which i'm not getting
    "Stick a V8 in it!"
    15,390
    Well first of i'd be checking the bulbs are installed properly, are the correct H7 fitment, and are properly seating into the bulb holder.
    If the lights were fine before, they should still be fine now.
    Oct 2010
    cornwall
    83
    yeah they sit in the bulb holders perfectly, the beam pattern is as it should be, but way to low...
    "Stick a V8 in it!"
    15,390
    Is it the same height with the proper H7 bulbs?
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,621
    Are your headlights standard reflector lenses or projector lenses?
    I found that using HID in standard lenses the beam was always low until I had adjusted the headlight.
    2002 2.5 V6 Quattro
    Oct 2010
    cornwall
    83
    no the normal h7's are fine
    Oct 2010
    cornwall
    83
    Quote Originally Posted by S4_dan View Post
    i assumed they were projectors but not sure now how do i tell? i have facelift lenses
    S4_dan's Avatar
    Jan 2006
    1,621
    Audi A4 B5 95-2001 Headlight Units Complete Pair+Bulbs | eBay
    Standard lights.
    A4/S4 B5 94-98 Projector Headlight R8 Look CH for AUDI | eBay
    Notice the glass dome in mddle light, thats the projector lense.
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    15,390
    If they're facelift lights they are projector for Dip and reflector for main. Typically you'd only fit the HID kit to the dip anyway, so the main beam should operate as normal, as its still on its original bulb.
    TBH thats a perfect example of why these kits are so shonky. The projector is designed around a particular light source, and the light sources are standardised. IE every H7 lamp will have the same geometry, as will every D2S burner.
    Clearly if your converting a H7 projector to HID you need the HID "bulb" to be geometrically similar to a H7, and presumably the muppets that made your kit havent done that.
    I'd suggest trying to find a different set of bulbs.
    S4_dan likes this.
    S4_dan's Avatar
    Jan 2006
    1,621
    Very true! There are some shabby cheap kits out there!!
    2002 2.5 V6 Quattro
    Oct 2010
    cornwall
    83
    many thanks for youre input and it would sound about right what you have said. i'll contact the seller and expain this to them and see what they have to say for themselfs....
