    jcb
    Sep 2005
    uk
    4,077
    help, key has died!
    took the battery out of my key and now I have no central locking and the alarm goes off every time I open the door with the key.
    do they need to be recoded or something?
    can I do this with VAGCom?
    jcb
    Sep 2005
    uk
    4,077
    forget that,
    I managed to find something to sort it after a mild panic!
    Press the unlock button whilst unlocking the car with the key
    Inset key in ignition and turn ignition on
    Turn ignition off and remove key
    Press the lock or unlock button
    It should now be synchronised
    worked a charm
    May 2010
    Bedford
    2,877
    You usually have 30 secs or so to change the battery before it loses programming so thats probably what happened. Glad its sorted now.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
