EM TuningChris Nott
    JS4
    May 2011
    23
    S4 Engine management light on
    Hi All,
    My Engine management cam on this morning as I was driving to work. So in the work carpark I plugged her into VCDS-Lite and came with the below report. The car has had a remap but has been fine since I bought it 3 months ago, the oil levels are all good also.
    Any ideas, I hate driving it if i know something is wrong.
    Code:
    VCDS-Lite Version: Release 1.0
    Monday, 18 July 2011, 08:12:33:0
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
    Address 01: Engine       Labels: 078-907-551-AZA.LBL
       Controller: 8D0 907 551 G
       Component: 2.7l V6/5VT         0002
       Coding: 10711
       Shop #: WSC 63251
       WAUZZZ8DZ1A147728     AUZ7Z0A1797577
    1 Fault Found:
    17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
                P1131 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes       Labels: 8D0-907-389.LBL
       Controller: 8D0 907 389 E
       Component: ABS/ESP allrad      D56
       Coding: 04395
       Shop #: WSC 06435
    No fault code found.
    Address 08: Auto HVAC       Labels: 8D0-907-389.LBL
       Controller:    ö8
       Note: Excessive Comm Errors
    Address 15: Airbags       Labels: 8D0-959-655-AI8.LBL
       Controller: 8D0 959 655 J
       Component: Airbag Front+Seite 2001
       Coding: 01106
       Shop #: WSC 63251
    Address 17: Instruments       Labels: 8D0-920-xxx-17.LBL
       Controller: 8D0 920 981 A
       Component: B5-KOMBIINSTR. VDO D12
       Coding: 00464
       Shop #: WSC 10001
    Address 25: Immobilizer       Labels: None
       Controller: Bit teA dre ssv
       Component: e 17 eingeben
    No Faults Found
      or DTCs not supported by controller
      or a communication error ocurred
    Address 35: Centr. Locks       Labels: 8D0-862-257.LBL
       Controller: 8D0 862 257 E
       Component: CV-Pump, Alarm, RC  D17
       Coding: 15178
       Shop #: WSC 63251
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
                35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
                35-00 - -
    01374 - Alarm triggered by Terminal 15
                35-00 - -
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
    01369 - Alarm triggered by Hood Switch
                35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
                35-00 - -
    00991 - Interior Lights
                28-00 - Short to Plus
    00955 - Key 1
                09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    Address 45: Inter. Monitor       Labels: 4B0-951-173.LBL
       Controller: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00102
       Shop #: WSC 63351
    Address 55: Xenon Range       Labels: 4B0-907-357-AUT.LBL
       Controller: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00012
       Shop #: WSC 63351
    Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
       Controller: 4B0 035 186 E
       Component:  Radio             0001
       Coding: 00013
       Shop #: WSC 63251
    End   --------------------------------------------------------------------------------------------------
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    1 Fault Found: 17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High P1131 - 35-10 - - - Intermittent
    Thats the important bit.
    One of your lambda sensors has failed.
    TD5 Land Rover Defender build
    JS4
    May 2011
    23
    Great, another £150 the B2 S1 sensors are on the down pipes as well arn't they? Are they particularly awkward to get to?
    "Stick a V8 in it!"
    15,379
    B2 is Bank 2
    S1 is sensor 1 (the top one, up near the turbo)
    Not sure which side of the engine is bank two though. I guess you can work it out by unplugging one side, and seeing if the fault code changes. IE if you unplug bank one by mistake its going to pop up a new code.
    The sensors are available direct from Bosch for a lot less than £150. I think its one of these you need: Just Lambda, Suppliers of zirconia and titania lambda sensors by post
    JS4
    May 2011
    23
    Thanks Aragorn, the master of all things Audi.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    A dying MAF can also cause spurious Lambda errors.
    Mo power, mo problems
