Sky InsuranceChris Nott
    Jun 2011
    54
    right a4 b5 rear speakers not working help
    ok i have a 110 se tdi 1996
    rear speakers dont work
    looks like wires are missing in block behind headunit
    the brown connector block only has 4 wires coming from it
    is there another block for the rear speaker on these with an aftermarket head unit
    any help appreciated thanks dan
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    from the factory the rear speakers are powered by an amp.As you have an aftermarket headunit,you need an adapter to connect the wires for the amp to your headunit.I changed the rear speakers and ran new wiring on mine.
    hth
    tony
    Jun 2011
    54
    right cheers thanks
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    The wires on the small yellow block are for the amp and rear speakers. one of the White wires, a yellow wire and purple i think iirc. One white one is a 12v remote for the amp. BUT, these wires are very thin and someone said they are earthed (all something to do with audi's amp)
    I ran some wire from HU to the rear nearside boot liner. In there is the terminal block for the amp. Red/Green & Blue/Green is right and left POSITIVE respectively. Brown/black & Brown/Red are negative.
    This is plug inside the trim area:
    2002 2.5 V6 Quattro
