    gmx
    Feb 2009
    Sydney
    132
    Central Locking flash signal
    ANyone have a wiring diagram handy for the flash/arm signals?
    I just removed an aftermarket alarm and they spliced into these wires coming from the CLU.
    I have no idea where they cut and I can't even find the suitable wires/harness underneath the kick panel.
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Surely the original wiring all must still be present and correct, or the central locking wouldnt work?
    If its jsut the flash output they've removed then try in the rear quarter panel area where the central locking pump is fitted.
    TD5 Land Rover Defender build
    gmx
    Feb 2009
    Sydney
    132
    It's been disconnected/spliced in at the point underneath the dash/kick panel harness. I disconnected them (from CLU) the alarm but can't find the original connections nor a harness with similar colour/gauge wiring.
    So I have no idea where they go.
    gmx
    Feb 2009
    Sydney
    132
    bump..... desperate for help.
    Been sitting like this for 3 months now.
    If anyones got diagrams or information I could take a look at myself, I'd appreciate it..
    "Stick a V8 in it!"
    14,900
    Get yourself a copy of Elsawin!
    gmx
    Feb 2009
    Sydney
    132
    Have a known good torrent linky?
