AH FabricationsSky Insurance
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,883
    Your boost readings in what gear ??
    What peak boost are you seeing in your gears 1st -5th as I want to now if mine is correct.
    TQS owners prefrably.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Aug 2010
    2,883
    Mines as follows
    1st - 5-6psi
    2nd - 6-8psi
    3rd - 8-10psi
    4th and 5th - same as 3rd
    B5QUAT's Avatar
    Apr 2011
    The North
    298
    Not sure about first, as I tend to be quite mechanically symapthetic, but in the other gears mine his 12 psi dead which tails off to about 8-10 as the revs rise.
    In 5th it sometimes hits 14 but more often than not, it's bang on 12, angain tailing off as the revs go up.
    Aug 2010
    2,883
    So looking at my readings there's something out of the ordinary then would you say ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Whats your airflow figures like on vagcom?
    AJL (and AEB) doesnt have a boost sensor. It works out the boost pressure using a load calculation based on the airflow, so if the MAF is a bit dodgy and reading incorrectly you can end up with squiffy boost. Your fuel trim values might also show something odd if its a MAF fault, and you did say you had a fault code about mixture, which again might point at the MAF.
    I dont have a gauge, but i've pulled a log thru second and the airflow figures show a nice flat torque curve ~170lb/ft which is the book figure, so would suggest that the car is making full boost in second gear.
    TD5 Land Rover Defender build
