Chris NottEM Tuning
Results 1 to 8 of 8
    Mar 2011
    suffolk
    249
    oil temp/oil cooler
    hi guys just wondering where your oil temp gauge sat when hot. my computer on ac reads 90 but needle on gauge is more like 100.
    have any of you guys fitted an aftermarket cooler and what are the benifits???
    Jun 2011
    bristol
    63
    mine is a 18.turbo and it sits around about 65/70 c but some times it reads 180 c think my sensor is a bit ify
    Mar 2011
    suffolk
    249
    think i might try new sensor too hate being paranoid lol
    Jun 2011
    bristol
    63
    ya i now what you mean cant stop checking lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    I suspect you've looked at the wrong channel on the AC unit. There are two, 49 and 51. Most guides say 51 is the temperature, however its actually 49, 51 jsut says 90c all the time once the engines warmed up.
    Mine sits spot on 90c on the oil gauge, and the coolant temp on 49 reads 91-94c depending on traffic etc.
    TD5 Land Rover Defender build
    Nov 2010
    Scarborough
    103
    60-70 depending upon weather and traffic conditions.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    "Stick a V8 in it!"
    14,949
    TBH it shouldnt be that low.
    The car has an oil to water heat exchanger, which should heat the oil up to the same temperature as the coolant, ie 90c.
    If its sitting lower than this, chances are you have a duff thermostat, and the whole engines running cooler than 90c. The coolant guage lies, and displays 90 once the temp gets to 75-80ish, so you can quite easily have a car thats running cold and get sits showing 90 on the dial.
    Use channel 49 on the climate diagnostics, or vagcom to view the actual coolant temperature.
    Mar 2011
    suffolk
    249
    did check channel 49 and 51 both read 85-90 so happy about that thanks aragon
