EM TuningBadger5
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,106
    Quick reply in workshop now !!
    Right still seeing 6 psi of boost since changing the splitR to a 007p it's better and not dropping to around 2psi at all as before I could see peak of 6 or 2 in low gears put code reader on this is what I have -
    00561 mixture adjustment control
    Is this because of the lack of boost or is this causing it ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    More likely an airleak or similar.
    From Rosstech:
    Possible Causes
    • Mass Air Flow Sensor (G70) faulty
    • Fuel Pressure too Low
    • Leaks in Intake Air System and/or Exhaust System
    • Injector(s) faulty (i.e. coked)
    Possible Solutions
    • Refuel Vehicle
    • Check Fuel System Pressure
    • Check Mass Air Flow Sensor (G70)
    • Check Intake Air System and Exhaust System for Leaks
    • Check Injection Quantity
    • Check Injector(s)
    TD5 Land Rover Defender build
    Aug 2010
    3,106
    My decat is blowing a bit as I couldn't tighten the nut under the manifold as the pipe was restricting it.
