Chris NottEM Tuning
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    What is the N75 mod ?? (Quick reply if pos)
    Has any one done this mod where you turn the screw on the top and if so would you recommend it or is it going to kill something ??
    I'm tempted to do this as I've got a brand new one which I don't think I'll have any problem shifting the screw on top.
    And what does it do does it kick the boost in quicker? Harder? Hold peak boost longer?
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Nov 2010
    Scarborough
    103
    N75 valves
    Anybody else done the N75 mod?
    First couple on google.Alters boost delivery by the sounds of it.Not delivering more boost so don't think it'll damage anything.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,918
    Done it on mine, do it to a spare as I can see how easy it would be to damage the valve as turning the screw is F**king hard. Only managed a ¼ turn on mine but it did make the boost a bit more aggressive in delivery and it did seem to hold the boost better at the upper end of the rev range. For a free tweek I can't complain
    Life begins at 140mph
    www.passionford.com
