Sky InsuranceEM Tuning
Thread: n75
    Jun 2011
    bristol
    63
    n75
    hi new to a turbo car but was does a n75 do. car felt a bit slow today not as much of a kick from the turbo but still boosting the same on the boost gauge cheers
    Nov 2010
    Scarborough
    103
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    The n75 controls the boost by opening the wastegate and closing it it's basically an electrovalve (electronically controlled vacuum valve) by the ecu !
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
