Volks AutosMonster Motorsport
Results 1 to 13 of 13
    hi to all
    Jul 2011
    west lothian
    6
    Unhappy oil light flashing on my 1.8t sport when i rev it
    when i rev it or pull away my oil light flashes at me when the turbo kicks in wat could this be plz help.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,353
    Stop driving the car or you WILL wreck the engine.
    Usual cause is a build up of sludge blocking up the oil pump, caused by inadequate servicing.
    TD5 Land Rover Defender build
    hi to all
    Jul 2011
    west lothian
    6
    think turbo seal is away blue
    smoke when let of gas
    hi to all
    Jul 2011
    west lothian
    6
    noise from turbo to when boost comes in
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    As aragorn says DO NOT DRIVE take the sump off and check the pick up pipe check the turbo compressor by taking the inlet off for any movement you may find it's catching on the housing if it is it's goosed. Use 5w40's fully synth and be sure to service every 6-8k miles !!
    "Stick a V8 in it!"
    15,353
    TBH its probably already fubar if you've been boosting around with it like that.
    Conrods will be making a bid for freedom next.
    hi to all
    Jul 2011
    west lothian
    6
    no have not been out in car since it happend was on way home when the light came on no ticks from top end but very bad sound from turbo when I reved it so not started from then
    "Stick a V8 in it!"
    15,353
    Ok. The dash ignores the oil pressure warning below 2000rpm. So you'll probably find that the pressure is low all the time, and your only getting a warning when you rev it or drive away becasue the engine then climbs over 2000rpm. Oil pressure increases with revs, so if its low enough to bring on the warning at 2k, its even lower at idle.
    Its a stupid design, but thats what Audi did.
    The usual cause is a blocked oil pickup. The cure is either to remove the sump and clean out the pickup, or remove the sump and replace the oil pump itself. Unfortunately that wont fix any of the damage that the low oil pressure has caused. By the sounds of it, your turbo has already seen the effects and the noise is likely due to its bearing having become damaged with the lack of oil.
    At this point you have a choice, you can either fit a new/used turbo (preferably along with a new oil feed line) and fix/replace the oil pump and hope the rest of the engine has survived, or you simply replace the engine as a complete unit.
    hi to all
    Jul 2011
    west lothian
    6
    thanks will take the sump of today just looks a big job to do
    Nov 2010
    Scarborough
    103
    It's not massive,just fiddly.Have a google for a guide.
    96 A4 Avant 1.8T sport
    Things to do:
    Sell it :-(
    "Stick a V8 in it!"
    15,353
    You will need to lift the engine up or drop the subframe off (or a combination of both) to get the sump past the subframe.
    hi to all
    Jul 2011
    west lothian
    6
    got it off with lifting the engine pick up blocked just going to change the pump to the turbo duz not hit at any point it has side to side movement no in or out play
    turbo charged
    Jul 2011
    west lothian
    you got it fixed yet
