EM TuningVolks Autos
Results 1 to 21 of 21
Thread: vagcom
    skinz's Avatar
    May 2011
    leicester, uk
    232
    vagcom
    dont want 2 b checky but has any1 got a vagcom near leicester, im having a couple of prob's with the car that i want to get checked out, i want to get 1 but with me getting married in a couple of month i cant afford it at the min and i dont want to get a fleebay hong kong special
    ive got a 96 1.8t
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    I've got a "hong kong special" and it works fine.
    Worth a shot for a tenner!
    TD5 Land Rover Defender build
    skinz's Avatar
    May 2011
    leicester, uk
    232
    every1 keeps tellin m e 2 stay away from them
    "Stick a V8 in it!"
    14,900
    They can sometimes be a bit tricky to get working and can require a bit of computer know-how to setup, but then what do you expect for a tenner!
    For what most people need them for, the ebay cables do the job just fine.
    Apr 2004
    Swansea, South Wales
    528
    I bought an ebay special for a fiver. Works a treat. But then again, I work in IT, so perhaps that helps.
    1999 S4, MIJ Performance exhaust with 100 cell cats
    skinz's Avatar
    May 2011
    leicester, uk
    232
    ok cheers peeps i'll try 1, its only a tenner suppose
    1,872
    It's going to work, but may take a little setting up on your laptop but for £10 it's worth the effort.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    is vcds vagcom or a differant version of vagcom ???
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    1,872
    Vcds is vagcom, but there are two versions lite & full, full will only work with genuine cables.
    Aug 2010
    2,870
    Bummer as I think I have downloaded the full version but the cables are about £250. How do I no if I have full or lite ?
    Apr 2004
    528
    dude, you on skype? if so and you get an ebay special £10 lead, i can talk you through it.
    Sep 2009
    34
    I bought an ebay special 2 weeks aho, and couldnt get it working ... Installed the drivers that came on cd, and program, and it woudlnt reconise the lead.... Got the error "No interface found" checked they were on the same com ports, tried 1,2,3,4, Tried different drivers found online, still no use.. Did this on win 7 laptop and an xp laptop.. But for a tenner i didnt loose any sleep over it lol.. I also know a good bit about computers.
    Apr 2004
    528
    I got both Vista and windows 7 working with ebay speical £10 lead no problem. You on skype? WOuld be easier to talk you through potential problems.
    "Stick a V8 in it!"
    14,900
    i've setup 3 different ebay leads without issue.
    Its typically just a case of ensuring the lead is on a sensible com port number, selecting the matching com port in vagcom, hooking it upto the car and off you go
    A common mistake people make is doing the interface test with the lead NOT connected to the car. the interface has two parts, one is a usb to serial converter powered by the laptops usb port, the other is a serial interface powered by the car.
    symun's Avatar
    Jun 2011
    Swansea
    147
    Bought one of the ebay ones this week, plugged the lead into the laptop and it installed drivers great.
    Next plugged into car then laptop, came up with the not found message.
    Opened the Device manager of laptop and clicked on the lead and it was connected to port 14, opened and changed to 1 then re-ran the test and it found it and click save.
    Thats the best way i can dumb it down sorry.......
    "Stick a V8 in it!"
    14,900
    Yep that more or less describes the methodology.
    You'll find you need to use the same USB port every time, as if you plug it in elsewhere it will move to another port.
    Sep 2008
    177
    How about this one Aragorn(Kev) ....Over 400 sold and cheap has chips..Looks ok what do you think..??
    VAG COM USB ODB2 DIAGNOSTIC CABLE 409.1 OBD2 II LEAD | eBay
    "Stick a V8 in it!"
    14,900
    looks alright.
    I've always gone with the blue ones, but they're probably all very much the same.
    slepy's Avatar
    No Audi but still here
    Sep 2009
    Sheffield
    910
    I've got a blue one which I don't need because I bought genuine one.
    If you want I can send you at a cost of postage or you can pick it up for free in Rotherham.
    2007 Honda Civic Type R daily. Soon for sale
    1999 Audi A4 1.8TQS - track car project
    Sep 2008
    177
    I have sent you a pm Mate..
    Apr 2004
    528
    My lead is blue. It has a green light. The green light is important. I've no idea how a lead could work without a green light.
