Results 1 to 14 of 14
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    S4 ABS pump differences
    Right i still havent managed to get my VCDS working so am just looking at the possible causes of the fault lights. My main ones i have on the dash are ABS with the bright RED light and 3 beeps as soon as i turn the ignition on. From doing a bit of research it seems that the ABS pump is a common fault. I actually have a receipt for £350 where it was reconditioned 3 years ago. After furter investigation, 2 of the 3 ABS fuses have been removed from my fusebox My ABS pump is part number 8E0 614 111A but i have found one from a V6 of the same year for cheap but it has an extra letter at the end of the part number 8E0 614 111AB
    Will this fit?
    Why would the previous owner have removed the 2 fuses?
    My other main faultlight is the airbag but again after reading on here, its more than likely a dodgy underseat connection
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,369
    I replied over on SRS. AB is a FWD pump. You need A or E.
    Stick the fuses back in and see what happens. Could just be a broken ring.
    TD5 Land Rover Defender build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Nice one mate, whats the difference between an E and an A then? I'll see if i can pick some fuses up whilst im at Audi tomorrow picking up my cam cover gaskets. Would the broken ring cause the 3 beeps on ignition? Im pretty stuck untill i get the VCDS working i think but i really want to get these lights put out
    "Stick a V8 in it!"
    15,369
    three beeps immediately means the ABS system isnt responding (presumbly because it has no power)
    Broken ring can cause the ABS to kick in all the time when braking, hence removing the fuse to stop it.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    AH right, got ya. Could i check for a broken ring visually or do i have to get my VCDS working to identify which one is knackered
    jamie226bhp's Avatar
    Aug 2009
    464
    If it's no power then it's quite often an abs ecu problem seen adverts on eBay to repair this for £100 as that's what mines doing
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by jamie226bhp View Post
    what Aragorn meant by no power was that the previous owner has removed two of the 3 ABS fuses. I'd be happy as a pig in ++++ if all it is, is an ABS sensor/ring. Isnt the ECU part of the pump? i know where you can get a FWD pump for a tenner. Worth a shot for that money
    Aug 2009
    464
    Mines a Quattro and the ecu just bolts to the side of the pump, apparently thet are prone to two if the joints on the circuit board giving up, when I plug ig in I get signal intermitant on
    The scan but can't remember the code off hand
    "Stick a V8 in it!"
    15,369
    FWD pumps dont have EDL, so wouldnt be suitable for a quattro.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    there is so called "how to" repair manuals on ebay, surely it cant be too difficult to repair PCB tracks?
    "Stick a V8 in it!"
    15,369
    afaik its some super fine wires that run between a connector and the PCB.
    Aug 2009
    464
    Would rather not risk it as its apparantly easy to ruin one and £100 isn't the end of the world for a fix
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    So whats the difference between the E and the A pumps? You said i could get away with an E or an A
    "Stick a V8 in it!"
    15,369
    They're the same.
    A supercedes to E.
