AH FabricationsVolks Autos
Results 1 to 11 of 11
    Jun 2011
    Coventry
    49
    what is ur idle rpm
    my car idles at 1000 RPM
    seems a bit to high most cars idle around 750-800
    how can I adjust this rpm
    maybe use VAGcom?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    iirc mine idles at 850.
    Its not adjustable afaik. You might find theres a fault code stored for something?
    TD5 Land Rover Defender build
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    yeah mines around 800-850 to
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,876
    Is there not a clip on the acc cable on the manifold that adjusts the cable travel you mace have it adjusted wrong ??? Just a thought.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jun 2011
    Coventry
    49
    Quote Originally Posted by Bradderz_1988 View Post
    will check tomorow
    Oct 2009
    Melb, Aust
    48
    about 900 for mine
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Teo's car is a DBW, so no cable. it CAN be adjusted: (see below) but i'd persue othe lines first, like DTC or other faults before tweaking the idle speed.
    Idle Speed Adaptation:With engine warmed up, at idle:
    [Select]
    [01 engine]
    [Adaptation - 10]
    Enter channel 01
    Enter an adaptation value between 124 and 132
    [Save]
    (May require a Login of 01283 or 11463, depending on year or model)
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    14,909
    TBH its far more likely that the ECU is keeping the idle high for a reason.
    Try doing a throttle body alignment and see if that helps.
    Jun 2011
    Coventry
    49
    its acting up today I had it through the MOT at work and noticed that the idle was down to about 850-900 but then later when leaving work it was still at 1000
    and the RPM needle moves very very little goes up and down only 1mm
    the engine doesnt seem to have any effect from that movement as I dont hear it revving up and down
    maybe I caused all this because when doing the engine swap last week I swapped the throttle body as well and had it cleaned real good i played with it alot to make it shiny maybe I fuked it up
    btw it failed the MOT
    front anti roll bar drop links need new bushings
    front headlights need to be fixed right
    already got the parts just need time to fit them
    also doing rear wheel bearings how hard are those to get out are they pressed in the hub assembly ???
    "Stick a V8 in it!"
    14,909
    You can do the rear bearings with a big screwdriver and hammer to tap the races out.
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by teo420 View Post
    Quite possibly. You really need to do a throttle body alignment on vagcom. that may sort it. or it may be pulling too much air in (ie: a leak in a vac line or other hose)
