Volks AutosEM Tuning
Results 1 to 12 of 12
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,115
    Boost hose clamp diameter ?
    Right the Frankenturbo order has finally been placed and I also want some new hose clamps aswel but what diameter clamps do I need ?
    Also can i definitely run the FT on the stock ecu without having any problems/issues ?
    Aug 2010
    3,115
    Anyone no the clamp diameter as I want to get them ordered for saturday as I've got a few bits n bobs I need to do on the car ??
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    which clamps?
    TD5 Land Rover Defender build
    Aug 2010
    3,115
    The boost hose clamps on both bottom hoses and IC to manifold pipe.
    "Stick a V8 in it!"
    15,324
    The clamps on the lower steel pipe and the turbo are "40-60x9"
    The two clamps on the OEM intercooler are "50-70x9"
    The clamp on the TB is "60-80x9"
    Aug 2010
    3,115
    Cheers for the info aragorn. Just about to order them and I haven't a clue as the above are jubilee dimensions if I'm correct and I'm after mikalor T bolt clamps heres my choices how many of which do I need to replace the 6 clamps you mentioned ?
    *** 1.75inch */* 47 to 55mm
    *** 2inch */* 54 to 62mm
    *** 2.25inch */* 60 to 68mm
    *** 2.5inch */* 67 to 75mm
    *** 2.75inch */* 73 to 81mm
    *** 3inch */* 79 to 87mm
    *** 3.25inch / 86 to 94mm
    *** 3.5inch / 92 to 100mm
    *** 4.0inch / 105 to 113mm
    "Stick a V8 in it!"
    15,324
    forget T clamps, they're ****.
    JCS Hi-Torque Jubilee clips are where its at.
    jamie226bhp's Avatar
    Aug 2009
    464
    Keep us informed on this kit as it looks good and let us know how much it was including the shipping and import duties etc
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    Aug 2010
    3,115
    Will do jamie the kit breaks down as follows -
    F4L F4L hybrid turbocharger kit for longitudinal 1.8T
    [3" MAF housing:Not needed]
    [Adapter gasket for OEM 2.75" MAF:Yes]
    [Diverter Valve:No]
    [In-line Fuel Pump w/ hose fittings:I'm thinking no] 1 $1,059.00 $1,059.00
    * Subtotal: $1,059.00
    * Tax: $0.00
    * Shipping Cost: $150.00
    * Grand Total: $1,209.00
    Converted by paypal was £771 and some pence havent a clue about import duties as yet but hoping there isn't any !!
    Also got a free t-shirt and I asked about a window sticker but they said they do badges instead so doug said they will make sure they include one !!
    Aug 2009
    464
    Will the maf size restrict potential power by much do you know
    Aug 2010
    3,115
    I think yes but not sure I should see around the same power i think on the stock ecu maybe a tad more because of the decat until i sort out the injectors, MAF, FMIC and a remap, but should spool quicker and hold peak boost longer but it's my first turbo car and my first go at tuning something so I'm no master of performance just going with it and hoping the outcome will be worth it !!
    "Stick a V8 in it!"
    15,324
    You'll almost certainly get hit with VAT at 20% and a little import duty on top assuming the customs declaration was completed correctly.
    MAF will start becoming restrictive at some point above around 220hp i'd recon. You'll absolutely need a 3" housing to get the most from an FT.
