The TQS pump is the same as the S4 one, and its good for 400hp+
The stock injectors however are hopeless, so those will likely need changed, and you'll also run out of MAF headroom as well.
TBH i'd suggest 3" MAF and bigger injectors, along with dropping the fuel pressure to 3 bar to give the pump an easier life.
