AH FabricationsChris Nott
Results 1 to 17 of 17
Thread: Help wanted
    Mar 2004
    Leicester UK
    133
    Help wanted
    Hi all i have just replaced my heater matrix on A4 B5 1.9 tdi 1997, right pain of a job, but the problem i am having is that I have no indicators no horn no outside tepmperature display fans will not stabilise. But i have a spare wire that has a brown cover on and it is a push on spade connector with a brown and grey wire which is a a permanet live, i thought it was to do with the heater controls so when I had all the dash out i laid it to the side with all of the other heater control wires but had nowhere for this connector to push onto. I have a picture of the wire which i will try and get up onto photobucket in the meantime.
    Mar 2004
    Leicester UK
    133
    In this picture below you can just make it out by the yellow box sat on the tunnel
    here is the cable when poked through the stereo apperture.
    Any ideas where this cable connects to?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,889
    It's not for the ashtray light or glove box light is it ?
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Mar 2004
    Leicester UK
    133
    Quote Originally Posted by Bradderz_1988 View Post
    Nope got both of them sorted cheers
    griswold's Avatar
    336
    Im sure i got the same wire behind my stereo?
    I changed the standard headunit for aftermarket and im sure that is one of the cables left over?
    I'm sure somebody will know what it is.
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Mar 2004
    Leicester UK
    133
    Quote Originally Posted by griswold View Post
    Maybe it is but that doesn't explain the other bits not working, maybe if I plug in vagcom will this show any readouts? as i can get hold of one?
    Mar 2004
    Leicester UK
    133
    found some pictures on the net and it does look like the a stereo lead or power lead but as mine has a JVC cd player in there obviously not needed then so if anyone can help with the other problems then.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Its just an earth for the stock head unit.
    TD5 Land Rover Defender build
    griswold's Avatar
    336
    meant to add. probably not related
    get a vag com cable and scan it
    Mar 2004
    Leicester UK
    133
    Ran a vagcom scan and it threw up these error codes?
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 B
    Component: A4 KLIMAVOLLAUTOMAT_D72
    Coding: 04144
    Shop #: WSC 06325
    4 Faults Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    29-10 - Short to Ground - Intermittent
    00792 - A/C Pressure Switch (F129)
    29-00 - Short to Ground
    00532 - Supply Voltage B+
    07-00 - Signal to Low
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    anyone got any ideas on any of these?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Its also an alarm trigger. if the alarm is armed and the HU is unplugged the alarm should go off
    Currently rolling in a SKODA!!!
    Mar 2004
    Leicester UK
    133
    also got no wipers as well, so there is obviously a electrical problem somewhere ???? but where do i start or look
    Mar 2004
    Leicester UK
    133
    Right then a mate of mine who is very good with fault finding diagnosed it down to the ignition starter switch, what i found weird was the fact that it would start but it would not supply the power to the electrics. £10.44 to replace form euro car parts, job done
    jcb
    Sep 2005
    uk
    4,070
    might be a stupid suggestion but have you checked the fuses?
    "Stick a V8 in it!"
    14,949
    Quote Originally Posted by Jules View Post
    Thats because there are 3 or 4 different contacts inside the switch, which are used for different things!
    Mar 2004
    Leicester UK
    133
    Quote Originally Posted by jcb View Post
    I did check all the fuses and it was down to the ignition starter switch as above.
    Mar 2004
    Leicester UK
    133
    Cheers I know now
