Monster MotorsportChris Nott
Results 1 to 19 of 19
Thread: Solid flywheel
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Solid flywheel
    Just had the flywheel cleaned, but think they got a little trigger happy. In this condition, would it destroy a clutch plate or would it just be a strong bite and then smooth out over time?
    Currently rolling in a SKODA!!!
    Arrkon's Avatar
    Oct 2010
    1,641
    Anyone have any advice?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,311
    Not really sure what your showing? is it rough?
    TD5 Land Rover Defender build
    Arrkon's Avatar
    Oct 2010
    1,641
    yeah, a little. kind of like rough wet n dry...
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    TBH i recon it would face off first few times of slipping.
    Arrkon's Avatar
    Oct 2010
    1,641
    i was REALLY hoping someone would say that... i was thinking it would, but needed reassurance I bet the first couple of launches would be awesome tho :D
    Oct 2009
    Melb, Aust
    48
    I think it will tear the disk apart, the surface should be machined.
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    Arrkon's Avatar
    Oct 2010
    1,641
    Quote Originally Posted by bmarshall View Post
    oh....
    Arrkon's Avatar
    Oct 2010
    1,641
    Just to be on the safe side, i've just put the flywheel into a shop to have it skimmed (and lightened too ) should see the results in the next 2 days.
    Oct 2009
    Melb, Aust
    48
    Good idea, you dont want to waste time having to do it all again if you have problems
    96 A4 1.8TQ
    'TO COME'
    Arrkon's Avatar
    Oct 2010
    1,641
    Conversion done. Feels to rev so freely now. Bite point really low, but I may solve that by adjusting the pushrod length. Remap next me thinks. BIG thanks to Jason (voorhees) for his help over this weekend.
    May 2010
    Bedford
    2,877
    So what clutch in the end did you actually use?
    And on the free revving side of things i wanted to weigh the standard set up when its out because according to the ECS weights on their site under the S4 conversion the standard set up weighs asmuch as my single/S2 set up when i weighed it...
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Arrkon's Avatar
    Oct 2010
    1,641
    Used a 1Z Tdi clutch for the time being (as it was sachs and cheap) but can upgrade at a later date if needs be.
    Didnt weigh the two FWs, but at a guess the SMF felt about 1-2kg lighter than the DMF
    May 2010
    Bedford
    2,877
    Hmm hopefully it is lighter then and ECS are wrong on the weights. I weighed my clutch/fly all bolted up together and it came in at 16.4kg`s (i think) and the ECS website lists exactly the same (without going and looking at the site)
    Arrkon's Avatar
    Oct 2010
    1,641
    The setup i used (when bolted together) didnt feel anywhere near 16kg. Totalled, felt more like 10 ish, but i could be wrong. the test will be tomorrow, when i up the power, and see if the clutch is upto the job.
    "Stick a V8 in it!"
    15,311
    I'd give the clutch some time to bed in before trashing it.
    I found the clutch to start bite very low, but required a fair amount of travel before properly hooking up when it was brand new, then after a few weeks the bite moved up a little and the travel from bite to fully engaged reduced, presumably as the two parts mated together.
    Arrkon's Avatar
    Oct 2010
    1,641
    Well after the travelling today, I think the clutch should have bedded. (down to London, circa 70-90mph, around London, on to Woking and back up to the midlands 80+some mph) few hundred miles worth plus clutch use in stop start London traffic...
    "Stick a V8 in it!"
    15,311
    stop start type driving is what you need really, ie slipping the clutch. 200miles on the motorway wont have done very much to bed it in.
    Hopefully be alright though, mine went onto a used unskimmed flywheel which had a slight ridge so maybe thats why it took longer.
    Arrkon's Avatar
    Oct 2010
    1,641
    Well the cars running peak 14psi now, couple of WOT's in each gear and no signs of slippage. Seems happy enough though I'm going to take it easy for the rest of the week.
