Sky InsuranceEM Tuning
Results 1 to 15 of 15
    Mar 2010
    125
    rattle on 98 S4 Avant
    Ok so i have a S4 Avant i am restoring as i got it very cheap, the car fires up ok which is a relief though it has some leaks. my main first concern is a rattle in the exhause somewhere near the front, how can i tel if its the Cats or the heat sheilds? and if its the Sheilds how easy to sort it is and where is there location etc etc.
    any help really appreciated
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    it could be the manifolds themselves, and if is, its pretty much an engine out job to change them
    TD5 Land Rover Defender build
    Mar 2010
    125
    omg really, the engine has to come out to change the manifolds, damn!
    "Stick a V8 in it!"
    15,350
    Yeh, and early cars had a known problem with the manifolds breaking up.
    Obviously you want to check it definately is the manifolds before ripping the motor out!
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    Remove the heat shields first if I were you. I had the same rattle on my 1998 2.8 avant a while back. I removed the heat shields (3 or 4 nuts If I remember right secures them per side) and the rattle went. Not a hard job at all.
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    Ardz83's Avatar
    Jun 2011
    weston super mare
    118
    I got the same thing,driving me crazy! I put new bolts in the heatsheilds bit it's still there.
    Apr 2004
    Swansea, South Wales
    528
    I had the heat shield thing, IIRC
    1999 S4, MIJ Performance exhaust with 100 cell cats
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,596
    ooooohh, another thread I can relate to!!
    I too, have a rattle from the manifold area. ONLY after giving my car a ride from hell! It loved it really. Or at least i did as the car performed and handled superbly with heel/toe driving!
    I've got two new manifold gaskets to fit. So i'm now hoping its the heat shields as it seems common.
    2002 2.5 V6 Quattro
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by tonybolony View Post
    How cheap did you get it for then and whats the spec on it? Any pics? Ive also just bought a cheap S4 project. Its arriving Monday morning and i got it for a bargain £1000. Just needs a bit of bodywork and the airbag and ABS lights sorting. Also a lambda sensor
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by LeeT View Post
    A bag of sand!!!!( In a dodgy Mike Brewer accent!) Where do you find bargains like this? Get some pics of these steals up please.
    Project RS28 build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by Foxmeister View Post
    ill get some tomorrow for you.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Sorry for the hijack OP but here you go Foxmeister. He wanted an extra £300 for the Avus' and i am going to change them anyway so didnt bother. You can just see the dented front wingand both drivers doors but nothing major at all. Has a full Milltek too
    Mar 2010
    125
    pretty car. i will get round to some of mine. It s a Blue Avant 1998 standard except for a 350BHP remap. Black Leather interior.
    Quick question if it is the manifolds i am guessing its a skin that rattles? could i pump loads of silicon between them? seen as it dont melt or burn? , will check heat shields first though, are they easy to locate?
    "Stick a V8 in it!"
    15,350
    The manifolds have a sort of inner pipework that carries the gas and then an outer shell round it.
    The inner pipes can break up at the end and come detached from the shell, causing the rattle, but more importantly, the bits of metal that break off go streight into the turbine wheel on the turbo, so if left unchecked will quite likely destroy the turbo when a big enough piece breaks off.
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Thats quite a steal mate, cheaper than my 2.8 cost me!!! Good find.
    Project RS28 build
